Post by allspeeds on May 4, 2019 8:00:32 GMT 1
Hi I have got mot coming up on my Lc2 ypvs as its an import I want to change the headlight glass to uk spec last time I put a sticker on it ,can anyone tell me if its the same part as the LC as I can't find the part. Thanks
Post by Shytalk on May 4, 2019 8:07:34 GMT 1
LC2 glass part number is 31K-84320, it’s the glass and reflector unit all in one piece, I don’t think the LC is the same.
Post by Yogi on May 4, 2019 8:07:56 GMT 1
Don’t think so as it’s got a 31k part number Lc parts are 41o
Post by allspeeds on May 4, 2019 8:33:01 GMT 1
Ok thanks guys ,don't suppose anyone got one for sale?
Post by midlifecrisisrd on May 4, 2019 9:56:37 GMT 1
Ok thanks guys ,don't suppose anyone got one for sale? I've converted a few by carefully removing an lc glass then fitting it into an lc2 euro one You remove the daft metal bit over the bulb too Steve
Post by JonW on May 4, 2019 13:48:49 GMT 1
I was led to understand that the headlight didnt dip to one side on our bikes, I must have read that wrong, hmm...
Post by midlifecrisisrd on May 4, 2019 13:59:56 GMT 1
I was led to understand that the headlight didnt dip to one side on our bikes, I must have read that wrong, hmm... Japan, UK and USA (and probably AUS) are flat beam so dip straight down Euro dips to right I was buying cheap USA ones, running a grinder round the outside edge which allowed the glass to be praised off in one piece Then hold the euro one upside down (to protect the reflector from the broken glass as marks really easy) Hammer the glass to break it then pick out the pieces Remove the remaining sealant used to bond the glass in. Pull the metal dome bit off then bead clear silicone around the edge before fitting the correct glass 😁 Steve
Post by JonW on May 5, 2019 0:34:40 GMT 1
Blimey Steve, luckily we dont really get 'reflector rot' here in Aus and dont have much access to Euro lights so its not been too much of an issue for us, but good to know
