Post by wangwang on Apr 22, 2019 16:51:18 GMT 1
Are the nyloc nuts that hold down the YPVS cylinders flanged? and if so, are they serrated or smooth?
cheers
wang
Post by LC_BOTT on Apr 22, 2019 17:12:33 GMT 1
Smooth and flanged, don't think they are nylocs though.
Post by Yogi on Apr 22, 2019 17:18:12 GMT 1
I don’t use nylocs on barrels it’s too hot and melts the nylon
Post by wangwang on Apr 22, 2019 17:45:42 GMT 1
Cheers, it's my first YPVS engine build and I started with just a set of damaged cases. It looks like this now, but with the top clutch bearing fitted.. 20190415_200138 wang
Post by Yogi on Apr 22, 2019 17:51:24 GMT 1
Looking good mate Don’t forget the half moon bearing retainer Matt
Post by wangwang on Apr 22, 2019 18:14:07 GMT 1
Oh yes, the two halves aren't sealed yet, waiting for some bolts etc.
What did I do wrong with the pic, How do you just insert it without the link?
Post by Yogi on Apr 22, 2019 18:23:03 GMT 1
It’s awkward but press bbcode then highlight the code until copy comes up,click copy Click on the forum,paste it ,then remove all text back to url and it should then work
I might put another thread on how to from an iPad
Post by wangwang on Apr 22, 2019 18:33:03 GMT 1
It’s awkward but press bbcode then highlight the code until copy comes up,click copy Click on the forum,paste it ,then remove all text back to url and it should then work I might put another thread on how to from an iPad I only have two options, share and email?
Post by Yogi on Apr 22, 2019 18:41:38 GMT 1
Post by wangwang on Apr 22, 2019 20:36:54 GMT 1
Post by markhoopy on Apr 22, 2019 22:32:12 GMT 1
Are the nyloc nuts that hold down the YPVS cylinders flanged? and if so, are they serrated or smooth? cheers wang Genuine Yam are £1.63 each - part number 9017908491 - plain nut, flanged. If you buy M8 flanged nuts from ebay or similar they are likely to be a 13mm spanner/socket rather than the 12mm Yam ones.
Post by midlifecrisisrd on Apr 23, 2019 9:39:47 GMT 1
Are the nyloc nuts that hold down the YPVS cylinders flanged? and if so, are they serrated or smooth? cheers wang Genuine Yam are £1.63 each - part number 9017908491 - plain nut, flanged. If you buy M8 flanged nuts from ebay or similar they are likely to be a 13mm spanner/socket rather than the 12mm Yam ones. Are they not superseded to olive now? Seem to remember buying new then having to replate them We need someone to cnc some 12mm ss flanged ones 😎 Steve
Post by muttsnuts on Apr 23, 2019 10:05:13 GMT 1
Genuine Yam are £1.63 each - part number 9017908491 - plain nut, flanged. If you buy M8 flanged nuts from ebay or similar they are likely to be a 13mm spanner/socket rather than the 12mm Yam ones. Are they not superseded to olive now? Seem to remember buying new then having to replate them We need someone to cnc some 12mm ss flanged ones 😎 Steve I have 12mm flanged nuts on the shelf if anybody needs some
Post by Yogi on Apr 23, 2019 10:36:55 GMT 1
Are they not superseded to olive now? Seem to remember buying new then having to replate them We need someone to cnc some 12mm ss flanged ones 😎 Steve I have 12mm flanged nuts on the shelf if anybody needs some Stick me some aside until my order please Dave
Post by muttsnuts on Apr 23, 2019 10:52:52 GMT 1
no worries Yogi, got about 200 on the shelf as I use them all the time
Post by wangwang on Apr 23, 2019 12:13:35 GMT 1
What difference does it make between the 12 and 13mm nuts?
Post by cb250g5 on Apr 23, 2019 12:52:43 GMT 1
What difference does it make between the 12 and 13mm nuts? 12mm is JIS (Japanese Standard) 13mm is ISO (international Standard - based in Switzerland I think) Either will stop your barrels falling off. I've had stainless 13mm plain nuts with washers on for the last 12 years. No probs.
Post by midlifecrisisrd on Apr 23, 2019 15:19:26 GMT 1
What difference does it make between the 12 and 13mm nuts? Nothing from a functional point Just the fact that the torque wrench adaptor to torque them correctly is 12mm Steve
Post by mellow on Apr 23, 2019 18:25:51 GMT 1
I bought 8 of these few weeks ago. they are dark olive, flanged and NO nyloc. From fowlers. While i'm here id love to know how you torque barrel nuts down. Can only get on the inner back 2 at best, outer rears and all fronts inaccessible
Post by headcoats on Apr 23, 2019 18:44:59 GMT 1
I had a special spanner from NK years a go that you put a torque wrench on the end and converts it that way but just a faff so just snugged them up and re checked a few times after heat cycles
Post by tell7437 on Apr 23, 2019 22:40:49 GMT 1
I use stainless m8 rod connectors cut to the length of the exposed stud (with a washer underneath), looks far better than having the threads showing, I do the same on exhaust studs,no good if you want originality though.
