Post by lolly on Apr 6, 2019 18:40:14 GMT 1
hello all
I have just installed a new central wheel spacer in the rear wheel of my 4LO , but it still doesn't feel right , if I try to tighten the nut too much it drags really badly .
has anyone got any pictures of all of the spacers in the rear wheel . I have looked on the fowlers parts list but it is blurred , I have looked at the Haynes manual but it is exploded and a bit confusing
thanks in advance
Post by oldelsieboy on Apr 6, 2019 19:12:45 GMT 1
hello all I have just installed a new central wheel spacer in the rear wheel of my 4LO , but it still doesn't feel right , if I try to tighten the nut too much it drags really badly . has anyone got any pictures of all of the spacers in the rear wheel . I have looked on the fowlers parts list but it is blurred , I have looked at the Haynes manual but it is exploded and a bit confusing thanks in advance Image borrowed from eBay OEB
Post by lolly on Apr 6, 2019 19:30:04 GMT 1
what I am confused about is in the Haynes manual , page 148 it shows a spacer behind the metal "dust cover" on the sprocket side , item number 15 , when I took the wheel off today I don't remember seeing that one
Post by oldelsieboy on Apr 6, 2019 19:36:01 GMT 1
what I am confused about is in the Haynes manual , page 148 it shows a spacer behind the metal "dust cover" on the sprocket side , item number 15 , when I took the wheel off today I don't remember seeing that one It is in the photo fitted inside the dust cover. Do you have the collar/spacer (no 8 in the Haynes diagram) fitted to the inside of the sprocket carrier? OEB
Post by tacky1 on Apr 6, 2019 20:29:35 GMT 1
2 spacers in the wheel, 1 Between the wheel bearings and 1 behind the sprocket bearing.
Post by lolly on Apr 6, 2019 21:25:02 GMT 1
2 spacers in the wheel, 1 Between the wheel bearings and 1 behind the sprocket bearing. I am still missing one , would you have the dims of the other one , I only have the long tubular one
Post by wangwang on Apr 6, 2019 21:28:22 GMT 1
Is everything correct in the sprocket carrier?
Post by JonW on Apr 6, 2019 23:49:27 GMT 1
Also while doing this check the back of the brake backplate, Ive seen the inside of that 'spacer' area get chewed away too.
Post by mattybeckett on Apr 7, 2019 0:57:27 GMT 1
Got this ...
Post by steeley on Apr 7, 2019 13:04:51 GMT 1
Hi doddy . The spacer in the l/h wheel bearing /in the manual they call it a collar 4. the bigger diameter fits to the inside of the wheel against the central spacer . The sprocket carrier bearing is 7 in the diagram and 8 is a collar for that .
Post by lolly on Apr 7, 2019 14:17:01 GMT 1
cheers
