Post by stusco on Apr 4, 2019 15:27:30 GMT 1
How long do I have before this stuff goes off it’s a can off 2k pro clear lacquer ,someone told me I have about an hour after mixing the hardener but it doesn’t say on the can
Post by midlifecrisisrd on Apr 4, 2019 15:45:34 GMT 1
Any stuff I've seen says use within an hour
Post by stusco on Apr 4, 2019 16:15:48 GMT 1
Cheers Steve
Post by LC_BOTT on Apr 4, 2019 16:25:35 GMT 1
I've used it before and it's still been sprayable from the can the next day, once sprayed on a panel etc, anywhere from 1/2 hour dependant on conditions and temp. I don't use it much though, so not a pro sprayer
Post by jackjabba on Apr 4, 2019 17:05:23 GMT 1
Hope you are not using it without an air feed mask.
Post by mark69 on Apr 4, 2019 17:13:51 GMT 1
If it’s an aerosol put it somewhere cold.
Post by abar121 on Apr 4, 2019 17:43:14 GMT 1
Yep, just about ok the next day. Use with a proper orgainc compound mask with plenty of ventilation. Even then it's a bit dodgy.
Good stuff though!
Post by LC_BOTT on Apr 4, 2019 17:57:12 GMT 1
Hope you are not using it without an air feed mask. Not me, after reading several horror stories, went and bought an air fed hood. Not cheap but health comes first nowadays
Post by JonW on Apr 4, 2019 23:12:09 GMT 1
Agree, Ive read and been told the stories. One bloke at the local paint shop test sprayed a dot of paint outside the front door of the shop to see if the colour match was good. Dropped down and was rushed to hospital and nearly died. Seems everyone reacts differently to this stuff, some people are more susceptible than others etc. Be careful... a mask isnt cheap but it could save your life.
Post by stusco on Apr 5, 2019 8:07:57 GMT 1
Ordered a mask There’s nothing alarming written on the can! Just the usual warning
Post by reggieperrin on Apr 5, 2019 10:11:44 GMT 1
once mixed, it's already starting to cure, even if it's still sprayable. the 2 hour quoted wind gives the best results. It's not an air drying coating obviously, so the chemical reaction has started. visit the website and read the instructions and the precautions. Air fed mask is best but a good corruptly rated filter mask is ok from experience. Ensure plenty of ventilation if not spraying outside.
Post by liffy16 on Apr 6, 2019 11:03:14 GMT 1
Use it myself with a good mask and plenty of ventilation it is damn good stuff but as mentioned its pretty dodgy stuff to breath in LOL !!
Post by bare on Apr 6, 2019 17:55:11 GMT 1
Dunno NO bike painting project is worth risking that type of death. IMO..Better to pay someone, properly equipped and with the skills to use catalysed paints.
Post by abar121 on Apr 8, 2019 12:06:59 GMT 1
My local pro painter uses an acrylic lacquer that is petrol resistant. He stopped short of telling me which one it is though
