neil
my 125
Head set
Apr 2, 2019 21:44:40 GMT 1
via mobile
Post by neil on Apr 2, 2019 21:44:40 GMT 1
Hi,just fitted tapered head set bearings and once the tin dust shield is in place there is only 3 or 4 threads showing for the adjuster nut. Is this normal? thanks
Post by wonkywheel on Apr 2, 2019 22:30:52 GMT 1
What model are you fitting it to, Mk1 or MK2? There are 2 different kits.
neil
my 125
Head set
Apr 2, 2019 22:59:17 GMT 1
via mobile
Post by neil on Apr 2, 2019 22:59:17 GMT 1
It's a mk1 suppose to be a mk1 bearing kit
Post by wonkywheel on Apr 3, 2019 19:30:12 GMT 1
It's a mk1 suppose to be a mk1 bearing kit Well I wouldn’t be happy with a few threads. Ok: here’s the bearing sizes for the MK1 kit. 25x48x13 30x48x15 This kit didn’t fit my MK2
neil
my 125
Head set
Apr 3, 2019 22:40:11 GMT 1
via mobile
Post by neil on Apr 3, 2019 22:40:11 GMT 1
Thanks for this will check it out. I think It will be ok as the top yoke will secure everything.
Post by andysh2 on Apr 7, 2019 15:12:42 GMT 1
I had exactly the same problem with mine but like you have said the top yoke bolt will hold it all in place.
neil
my 125
Head set
Apr 7, 2019 22:47:25 GMT 1
via mobile
Post by neil on Apr 7, 2019 22:47:25 GMT 1
Thanks for your help chaps now cracking on with the build
Head set
Apr 8, 2019 19:02:02 GMT 1
via mobile
Post by jazzyjembreaze on Apr 8, 2019 19:02:02 GMT 1
I bought a set and the tolerance was shocking Reverted to buying original roller bearing set
