Post by mellow on Mar 27, 2019 10:30:44 GMT 1
Morning men. Would like to remove old threadlock from clutch bearing holder screw holes before refuting. Anyone know any substance that dissolves it? Cheers.🙂
Post by headcoats on Mar 27, 2019 12:36:53 GMT 1
Tap and die kit
Post by raven13 on Mar 27, 2019 12:42:25 GMT 1
Post by Deleted on Mar 27, 2019 16:07:55 GMT 1
MEK, Acetone, super glue remover should all dissolve it
or you can use localised heat
Post by kostas on Mar 27, 2019 16:09:55 GMT 1
MEK, Acetone, super glue remover should all dissolve it or you can use localised heat A few people know what MEK is.. but it does work miracles
Post by mellow on Mar 27, 2019 17:32:00 GMT 1
thanks chaps
Post by steeley on Mar 27, 2019 17:37:35 GMT 1
Hmmm MEK . Use with caution , I seem to remember reading about a chap got some In a paper cut and the cut wouldn't heal .when it did heal up he noticed a lump. Trip to the Dr .Then the Hospital to have lump removed ,ended up losing arm up to the elbow . Not Nice.
Post by kostas on Mar 27, 2019 20:36:09 GMT 1
Hmmm MEK . Use with caution , I seem to remember reading about a chap got some In a paper cut and the cut wouldn't heal .when it did heal up he noticed a lump. Trip to the Dr .Then the Hospital to have lump removed ,ended up losing arm up to the elbow . Not Nice. Use it every day.. it’s a real pain when even a tiny bit gets in any tidy cut on your hand. Never had any lump forming but this doesn’t mean it cannot happen. Gloves is a must. Worst stuff out there, like Mastinox
Post by mellow on Mar 27, 2019 20:39:16 GMT 1
I've done it now thanks chaps🙂dont worry not a drop of MEK was present 😁👍
Post by headcoats on Mar 27, 2019 20:50:39 GMT 1
What did yer do then !
Post by midlifecrisisrd on Mar 27, 2019 20:57:42 GMT 1
Think I need to buy some MEK
I can store it beside my DCM and my chromate based passivates
I've got more scary sh1t than Saddam allegedly had 🤣🤣🤣
Post by mellow on Mar 27, 2019 21:04:34 GMT 1
Would you believe cellulose thinners & cotton bud😁👍
