Post by philmill on Mar 25, 2019 21:34:47 GMT 1
Just a quick couple of questions, will an older FZR tacho work on a 31k, or does it need to be from a 2 cyl bike? I'm using FZR clock housings on my Hybrid and wondered if I can just use that tacho. And which wire is the take off to run and electronic tacho??
Thanks. Phil
Post by philmill on Mar 26, 2019 10:11:31 GMT 1
Anybody??
Post by midlifecrisisrd on Mar 26, 2019 14:38:03 GMT 1
Sorry, saw this late last night and forgot to message this morning
The ypvs tacho does not use a pulse, it uses the pv signal so won't work I'm afraid
Also the rd's use a wasted spark so if you took a pulse signal from the coil for a 4t tacho it would show double the rpm as 2 pulses per rev instead of 1
If you have a Zeel or an ignitech fitted these have a 1 pulse per rev signal on them which could drive a 4t tacho
Post by philmill on Mar 26, 2019 15:50:39 GMT 1
Thanks Steve, so would a TZR one work? And isn’t just a case of taking a wire from the CDI somewhere? Or I see you mention coil!
Thanks, Phil
Post by midlifecrisisrd on Mar 26, 2019 16:58:07 GMT 1
If you want an elec tacho on an lc2 you can use an f/n/r/tzr2ma rev counter with the power taken from the temp gauge and the trigger from the signal wire from cdi to pv controller
Some later 2 strokes use a combined cdi/oh controller so signal is a pulse from the coil
Later tzr's and the 3hm1 rz250 are like this
Post by philmill on Mar 26, 2019 17:41:27 GMT 1
Cheers Steve. I’ll keep an eye out for one, shame as I like the position of the needle on the FZR tacho. There’s a couple of TZR ones on eBay at the mo.
Post by midlifecrisisrd on Mar 26, 2019 18:47:57 GMT 1
I likes the far needle position too
I did make one up once with an fzr face and ypvs guts
