Post by philmill on Mar 13, 2019 18:34:36 GMT 1
Post by headcoats on Mar 13, 2019 18:47:43 GMT 1
I like the Negro one LOL
Post by philmill on Mar 13, 2019 18:50:51 GMT 1
They have some quite nice rear sets too! allow for the std exhaust fitment and rear footrests if you need them.
Phil
Post by midlifecrisisrd on Mar 13, 2019 19:02:58 GMT 1
Separate billet heads are a nice 😎
Only concern is the comment about more cooling at the exhaust port
The cool head can be criticised for reducing cooling on the barrels due to not pushing coolant from the rear of the head, down through the barrels and up into the front of the head
If this is the same kind of thing then maybe a concern
Post by dusty350 on Mar 13, 2019 19:05:21 GMT 1
I've seen the heads on Faceache, but hadn't seen the rearsets. They are lovely (rearsets) and seem well priced Dusty
Post by mouse on Mar 14, 2019 9:00:31 GMT 1
That stuff does look really nice, like the rearsets, seems they have adapters for pillion footrests too.
Also their yokes look lovely, seem to even have a built in damper mount, but i thinks they are only for standard YPVS forks, i think, maybe...
my Spanish is none too hot!
Mouse
Post by Tobyjugs on Mar 14, 2019 9:58:16 GMT 1
Separate billet heads are a nice 😎 Only concern is the comment about more cooling at the exhaust port The cool head can be criticised for reducing cooling on the barrels due to not pushing coolant from the rear of the head, down through the barrels and up into the front of the head If this is the same kind of thing then maybe a concern Steve It looks like a well designed cylinder head and the coolant is routed in the same fashion as Yamaha. It looks like it holds more volume than a standard cylinder head. This would be the cylinder head i would choose in place of a standard head for a YPVS engine. Being modular it would be very easy to make small modifications to suit your frame. I guess there are some pros and cons as it is two separate cylinder heads. I am very positive about this design.
Post by dusty350 on Mar 14, 2019 10:02:48 GMT 1
Post by dusty350 on Mar 14, 2019 10:04:47 GMT 1
You'll see the translation into English Dusty
rhrc
Post by rhrc on Mar 14, 2019 10:19:20 GMT 1
Post by headcoats on Mar 14, 2019 10:19:28 GMT 1
Does it look like it uses the standard head bolts ?
