Post by marrcel on Mar 6, 2019 11:47:38 GMT 1
I hope this basket is to repair. How much can be filed? This my first on a clutch plates exchange and i fear of removing the basket. Although i have basket holding tool.
Post by markhoopy on Mar 6, 2019 13:20:54 GMT 1
I hope this basket is to repair. How much can be filed? This my first on a clutch plates exchange and i fear of removing the basket. Although i have basket holding tool. If you have a clutch holding tool it is quite easy to remove the basket - presuming you have a big enough socket of course. You should be able to repair the basket I have seen photos showing wear ridges worse than yours that have been tidied up ok in the past. Make sure you fit a new locking washer when you put it all back together too.
Post by marrcel on Mar 6, 2019 15:31:44 GMT 1
Thanks Mark for the quick reply. Your answer is a relief to me. How much shall i file off? Complete flat or the isles of wear just visable?
Post by steeley on Mar 6, 2019 17:37:05 GMT 1
This may help .
Post by Tobyjugs on Mar 6, 2019 19:17:57 GMT 1
Hi Marrcel I have filed a couple now, just keep in mind once you file the basket it will make more of a rattly noise.
Post by stusco on Mar 6, 2019 19:40:27 GMT 1
Draw file till smooth
Post by marrcel on Mar 10, 2019 9:20:16 GMT 1
Done! Thanks for the advice.
