Post by midlifecrisisrd on Mar 4, 2019 14:36:40 GMT 1
Anybody used these? Any thoughts?
Considering a set for my "budget" hybrid build
Post by Deleted on Mar 4, 2019 16:21:14 GMT 1
hi Steve
i have the sport demons on my 31k and happy with them i wanted a stickier tyre and wasnt worried about wear, i was told the bt45 was a better all round tyre though
hth
Post by midlifecrisisrd on Mar 4, 2019 16:45:08 GMT 1
Grip was my concern so that helps
The fact they are only £96 a pair delivered also helps
Another factor is my rz250r has a nearly new pair fitted and the rear is a 140 and the front 100. I feel the rear is too wide for the rim
I'd prefer a 130 on it and I am building the "budget" hybrid which will have a 140 on it
If I buy a 110 and a 130 I can then mix and match the 4 with a 100 and 130 on the rz and a 110 and 140 on the hybrid
Anybody else?
Post by stusco on Mar 5, 2019 8:24:12 GMT 1
Try www.tyretectrading.co.ukGot mine there cheap as chips £7.50 delivery per pair na just looked up Pirelli not cheap ! I must have been lucky with the Avon’s
Post by Deleted on Mar 5, 2019 9:49:23 GMT 1
Anybody used these? Any thoughts? Considering a set for my "budget" hybrid build Steve I wouldn't fit them on a LC, Lc's are too light/powerful to make the tyre work. I had Angels on a YZF750. They were pants. The Demon was originally (alongside the Phantom) a decent tyre for classic and older bikes. Of the two (if you must) I'd go for the Demon. Or save up and put Avon's on the hybrid. Extra £150 on tyres to save £1,000's if it slides up the road on concrete tyres
Post by midlifecrisisrd on Mar 5, 2019 9:57:26 GMT 1
Anybody used these? Any thoughts? Considering a set for my "budget" hybrid build Steve I wouldn't fit them on a LC, Lc's are too light/powerful to make the tyre work. I had Angels on a YZF750. They were pants. The Demon was originally (alongside the Phantom) a decent tyre for classic and older bikes. Of the two (if you must) I'd go for the Demon. Or save up and put Avon's on the hybrid. Extra £150 on tyres to save £1,000's if it slides up the road on concrete tyres Cheers for that, glad I dodged the angels. I've bought a set of the Demons. It solves the oversize rear on the rz and matches the front which doesn't even looked properly scrubbed. The "budget" hybrid build will be a project I'm going to start soon that I'm trying to see how cheaply I can do it for a laugh. It will be a bitsa made from all the spare bits in my garage. I have the frame, engine, running gear and bodywork so why not Will do it alongside a "mint" hybrid build so one gets the wheat, one gets the chaff Steve
Post by abar121 on Mar 5, 2019 13:22:17 GMT 1
I was considering an Avon Streetrunner on the front of a stock LC and an AM26 on the rear that will just be toddled around. S rated, so no good for a 31k though.
Post by Deleted on Mar 5, 2019 14:27:25 GMT 1
Post by abar121 on Mar 5, 2019 15:50:37 GMT 1
Have you tried those Heidenau tyres, they look interesting?
Post by Deleted on Mar 5, 2019 18:22:06 GMT 1
I have a set of Heidenau in the loft. Recommended by Tony Salt Tyres. Sadly I have not had chance to try them out yet. They are supposed to be very very good.
Post by bare on Mar 5, 2019 18:25:00 GMT 1
replaced the Bridgestones (I forget) on My 600RR with Pirelli Diablo Corsa Reds. A whole new world of improvement. These are amazingly good tires. Also required Zero balancing weights as quality testament Worth Every cent I paid.. which actually wasn't that much of a premium over cheaper tires. Had no idea pirelli made tires in stock LC 350 sizes.
Post by allspeeds on Mar 5, 2019 19:05:51 GMT 1
I have just taken a new Heidenau off the front of my LC2 basically because I didn't like the look ,its 2016 and done 111miles if any one wants it they can have it for £20 plus postage.
Post by midlifecrisisrd on Mar 5, 2019 19:47:27 GMT 1
replaced the Bridgestones (I forget) on My 600RR with Pirelli Diablo Corsa Reds. A whole new world of improvement. These are amazingly good tires. Also required Zero balancing weights as quality testament Worth Every cent I paid.. which actually wasn't that much of a premium over cheaper tires. Had no idea pirelli made tires in stock LC 350 sizes. Not strictly an lc Rz250r 3hm1 The only powervalve to have 17 inch wheels as standard Like fzr250 2kr running gear, not sure if you had them over there Steve
chrisk
Post by chrisk on Mar 5, 2019 21:59:04 GMT 1
Conti classic attack. Radial On lc2.
Took a fair bit of setting up to get confident with the feel. Rear tyre profile looks odd, not too much profile, and very easy to be on the edge. Improved by only running around 26psi, really good feel, grip, and stable at speed at a good lean angle. Much better than Avon once pressure sorted, looks a bit naff due to profile.
Front tyre, is just sooo much better than the Avon before. Better grip, better ride, better turning.... great profile, looks better.
