binge
Post by binge on Mar 3, 2019 20:37:01 GMT 1
Hi I've just seen a boost bottle for sale on ebay for a rd350lc the add states that it increases throttle response and midrange power do they deal work?
Post by midlifecrisisrd on Mar 3, 2019 20:39:44 GMT 1
Some have done a before and after dyno test and it lost power
Some say it helps if you have a stutter or flat spot
Post by rigga on Mar 3, 2019 21:45:49 GMT 1
I have a boost bottle, and a while back someone on here kindly sent me a standard link tube, so I could see if there was any difference, nothing scientific, just how the bike felt with either ..... Felt better with. But that could be placebo, down to my particular set up, or even I just convinced myself because I like the way it looks Not helping am I ....
Post by steeley on Mar 3, 2019 22:06:56 GMT 1
Hi ,I have a 350lc with one on . I think it makes a difference . No scientific proof but there you go . Also I have made my own for my Tzr350 project ,again no proof but I think it helps .
Post by stusco on Mar 3, 2019 22:10:20 GMT 1
Looks good always a plus
Post by shaunthe2nd on Mar 3, 2019 22:16:18 GMT 1
I have a boost bottle, and a while back someone on here kindly sent me a standard link tube, so I could see if there was any difference, nothing scientific, just how the bike felt with either ..... Felt better with. But that could be placebo, down to my particular set up, or even I just convinced myself because I like the way it looks Not helping am I .... You are, I think you are really saying no notable difference.
Post by rigga on Mar 3, 2019 22:59:52 GMT 1
I have a boost bottle, and a while back someone on here kindly sent me a standard link tube, so I could see if there was any difference, nothing scientific, just how the bike felt with either ..... Felt better with. But that could be placebo, down to my particular set up, or even I just convinced myself because I like the way it looks Not helping am I .... You are, I think you are really saying no notable difference. As I recall back to back, bottle felt better pick up, but as said no way of backing that up with hard facts, as people say, seat of the pants dyno (hate that phrase) made me think bottle over tube, but other's have dyno tested and lost a HP or two. And to add to the mix, I run ypvs inlet rubbers, so the boost tube has wider inlets over the LC version, for what its worth
Post by Norbo on Mar 4, 2019 8:56:58 GMT 1
Its been my experience that if the bike is standard they do do nothing other then look nice .Id fit one on that basis alone. However the more tuned the bike that better they are and if you run ypvs reed blocks with a hybrid bottle they are even better again. i have seen dynos adding 2 BHP all they the range once one was fitted on a tuned bike
Post by aid22 on Mar 5, 2019 9:09:35 GMT 1
Its been my experience that if the bike is standard they do do nothing other then look nice .Id fit one on that basis alone. However the more tuned the bike that better they are and if you run ypvs reed blocks with a hybrid bottle they are even better again. i have seen dynos adding 2 BHP all they the range once one was fitted on a tuned bike Can the size or shape of the bottle make a difference?
Post by dusty350 on Mar 5, 2019 9:24:52 GMT 1
I think so. I remember reading an article where someone was testing, in depth, the theory of boost bottles, and the best design was much, much bigger than the ones we fit. It wasn't actually attached to the rubbers themselves as it wouldn't fit ! I would fit one coz they look great, but wouldn't expect it to transform the performance, either way. Dusty
Post by Norbo on Mar 5, 2019 9:46:48 GMT 1
Its been my experience that if the bike is standard they do do nothing other then look nice .Id fit one on that basis alone. However the more tuned the bike that better they are and if you run ypvs reed blocks with a hybrid bottle they are even better again. i have seen dynos adding 2 BHP all they the range once one was fitted on a tuned bike Can the size or shape of the bottle make a difference? Yes a one with ypvs inlets have a bigger bole and the bigger the bottle the better
Post by 0h5h1t on Mar 5, 2019 14:08:16 GMT 1
I think boost bottles are a marmite object. I don't have experience of them myself as I've always thought them a waste of time and money and are butt ugly. Even if one did give me 2bhp I wouldn't fit one for that reason alone. so yea, marmite. Love it or hate it
Post by aid22 on Mar 5, 2019 14:23:41 GMT 1
I hate Marmite . Will that make a difference?
Post by 4l04ever on Mar 5, 2019 14:38:53 GMT 1
I had one on my tuned LC. Lost about 0.5hp compared to standard pipe, so it was removed.
Post by muttsnuts on Mar 6, 2019 10:32:01 GMT 1
yep, generally they lose power on a stockish engine, have some dyno graphs somewhere I think, I'll try and dig them out. They do work on bikes that rev really high e.g. RGV's, TZR's, Aprilia RS's etc
I have found that having "no" tube at all is actually better, but I am not getting into all that as it requires a few other tweaks to the carbs
HTH
Post by Tobyjugs on Mar 6, 2019 12:18:51 GMT 1
yep, generally they lose power on a stockish engine, have some dyno graphs somewhere I think, I'll try and dig them out. They do work on bikes that rev really high e.g. RGV's, TZR's, Aprilia RS's etc I have found that having "no" tube at all is actually better, but I am not getting into all that as it requires a few other tweaks to the carbs HTH Bob Farnham and Higgsy gave me two plugs for the balance pipes and told me that it was also better. I could not get the engine to work well and ended up putting the balance pipe back.
Post by 4l04ever on Mar 6, 2019 12:27:21 GMT 1
I also removed the two boost bottles on my 3XV track bike, as the equivalent TZ (4DP) does not have them.
Boost bottles are probably best tested on a dyno to see if they make a measurable difference or not.
Post by muttsnuts on Mar 6, 2019 15:13:11 GMT 1
I also removed the two boost bottles on my 3XV track bike, as the equivalent TZ (4DP) does not have them. Boost bottles are probably best tested on a dyno to see if they make a measurable difference or not. yep, good job I have one of them !! - been doing loads of development recently as well, making some good power with some new software I am using, well happy with the results so far
