Post by aid22 on Mar 1, 2019 12:29:46 GMT 1
Had these done the other day and I was surprised how good they turned out. This is the first time I have ever had anything vp'd so have nothing to compare to. What do other members think of the result? Thanks, Aid. DS
[url=https://flic.kr/p/2eYYKBV
Post by 4l04ever on Mar 1, 2019 16:54:36 GMT 1
I have seen cleaner....
Post by stusco on Mar 1, 2019 17:17:00 GMT 1
Usually much better sorry to say
Post by badger1 on Mar 1, 2019 17:32:49 GMT 1
Yeah like the others have said, looking at the photos they have missed loads of places. I would have had a moan.
Post by veg on Mar 1, 2019 19:51:51 GMT 1
Hate to say it but mine were immaculate, you do need to degrease before hand and they should blank everything, but i think they could be better.
Post by aid22 on Mar 1, 2019 19:52:15 GMT 1
So how much would should I expect to pay for crank cases vp'd?
Post by headcoats on Mar 1, 2019 19:56:52 GMT 1
Take no notice, apart from a few little areas they are fine and underneath !
Post by 4l04ever on Mar 1, 2019 20:05:26 GMT 1
About £45 is average in the Midlands...
Post by markhoopy on Mar 1, 2019 20:11:20 GMT 1
TSR did these for me ..
Post by dusty350 on Mar 1, 2019 20:15:51 GMT 1
Is that definitely a vapour blasted finish ? I ask as mine always look like Markhoopey's. I pay £50 for a set of crankcases (London area) Dusty
Post by Yogi on Mar 1, 2019 20:23:52 GMT 1
I was paying £45 in Essex area last year As said though they normally look like Marks
That said yours don’t look that bad,if your painting the top case they’ll be ok
Post by aid22 on Mar 1, 2019 21:04:26 GMT 1
Mmmmmm? Thanks to everyone for their input. It's down to what you expect, what you want and how much you are prepared to pay. I also think that preparation is very important. I have to say that I think they have turned out good considering what they like before hand. Agreed though, there is room for improvement, compared to Hoopy's.
Aid.
Post by veg on Mar 1, 2019 21:27:33 GMT 1
Mine were like marks cost me £50 in the east midlands
Post by donkeychomp on Mar 1, 2019 23:13:45 GMT 1
Mine turned out better than that afraid to say and they were truly awful when I left them to get blasted. £30.
Post by midlifecrisisrd on Mar 2, 2019 11:28:41 GMT 1
It depends on the blast media
I know a place that can only get that kind of result but he uses a very fine glass bead
He is a polishing business so not really trying to be rougher as it will get buffed with a mop and compound after
The better finishes will have a rougher media or even aluminium oxide
Post by alistair64 on Mar 2, 2019 12:24:32 GMT 1
Hi Where would you guys recommend to go then (Midlands/East Midlands area)? Crankcases are always very telling when it comes to how good the job has been done. Do you mask off the gasket faces and crankcase mouths/should they do it for you, as it's hard to tell from the photos?
Thanks.
Post by midlifecrisisrd on Mar 2, 2019 12:32:41 GMT 1
Nothing gets masked as it should not remove any material from the casings
I use f and j and just post each way
Got a load waiting to go off to them
Post by dusty350 on Mar 2, 2019 13:00:09 GMT 1
Just fit bolts into all the blind, threaded holes. It saves effort afterwards trying to rinse media out of them, although you should always rinse well when you get them home to make sure nothing is left. The media is very fine, almost powdery, but coupled with the water pressure it makes for a very effective, but non damaging cleaning medium. You can alter the finish with vapour blasting depending on whether you want a more matt or satin finish. Parts come out looking like they have been sprayed with silver paint - that's why I wondered if Aid's had actually been vapoured - it doesn't look an even finish like the pic Markhoopey has added. I think Aid's look ok, but just not like a vapoured finish I've seen before. Dusty
Post by veg on Mar 2, 2019 14:20:58 GMT 1
Guy in Leicester did mine old boy back of the house type set up but he did a stellar job for £50
