Post by philmill on Feb 21, 2019 18:56:30 GMT 1
So what do we think about Non-genuine cables?? Norbo has some on his site that he lists as "OEM quality", anybody used them? I remember reading something Arrow said about problems setting up oil pumps using non-gen cables hence my question. Also, clutch cables, anybody used Norbo's for this too?
Just seeing what people think before I push the button on my next order......
Phil
Post by midlifecrisisrd on Feb 21, 2019 19:11:10 GMT 1
I've always used genuine, just my preference really
There are some crap cables out there that the oil cable won't adjust correctly as the wrong length
Can't comment on Norbo's as never used them but sure he doesn't sell crap.
Clutch cables are my big gripe. There are at least 3 different types which all have different inner and outer lengths
Cheap pattern cables seem to be a compromise between these and sold to fit all
Pattern ones tend not to have the black Teflon liner over the inner cable which makes the action so much lighter
You can see it clearly on the genuine one
I have recently picked up a fake one sold as genuine with the correct markings on it but no visible Teflon 🤔
Post by marrcel on Feb 21, 2019 20:13:54 GMT 1
steve at which end of the cable do you look? At the carbs 45deg bend?Or at the throttle?
Post by midlifecrisisrd on Feb 21, 2019 20:32:04 GMT 1
steve at which end of the cable do you look? At the carbs 45deg bend?Or at the throttle? It was the clutch cable I was referring too but the genuine throttle has them visible at the carb ends too I'm sure Steve
Post by muttsnuts on Feb 21, 2019 20:46:13 GMT 1
hence why I make my own and use teflon lined outer cables.......
Post by JonW on Feb 22, 2019 1:13:15 GMT 1
Cables are part of the few parts of a bike you have your hands on, even tho its not directly. Having decent cables will give the bike a lighter feeling when riding. I always use OEM on my builds.
Post by bazzer5115 on Feb 22, 2019 8:44:45 GMT 1
Make your own from venhill kit,as good as oem. If you building a special (as I do) why try to adapt something that could never be right. Simply make your own bespoke cables-simple👍
Post by philmill on Feb 22, 2019 10:53:22 GMT 1
Ok, so genuine seems to be the choice unless you can make your own, but I dont see any genuine clutch cables for sale anywhere! any sources you can suggest?
Phil
Post by midlifecrisisrd on Feb 22, 2019 13:10:13 GMT 1
Ok, so genuine seems to be the choice unless you can make your own, but I dont see any genuine clutch cables for sale anywhere! any sources you can suggest? Phil Pm on its way Steve
