Post by philmill on Feb 19, 2019 17:15:29 GMT 1
Is this as far in as this one goes? It’s the one behind the cable wheel (l/h side) Phil
Post by midlifecrisisrd on Feb 19, 2019 17:22:00 GMT 1
The bush should sit flush with the face the pulley bolts to
The lh bush is thicker than the inner ones so looks like the wrong bush is fitted
Post by philmill on Feb 19, 2019 17:23:14 GMT 1
Thanks Steve, I bought the bushes from Norbo, I got three the same! So it’s not right then. I’ll drop him a line.
Post by midlifecrisisrd on Feb 19, 2019 17:23:14 GMT 1
Should also say the lh bush does not usually wear so if you have the old one....
Post by midlifecrisisrd on Feb 19, 2019 17:26:59 GMT 1
You can see the thicker one in this eBay pic Steve
Post by philmill on Feb 19, 2019 17:28:55 GMT 1
Yes I have, it measures 17.3 inside, so will try it. I guess it’s this one?
Post by philmill on Feb 19, 2019 17:29:24 GMT 1
Any tricks for getting the new one out with barrels on?
Post by stusco on Feb 19, 2019 17:32:53 GMT 1
Maybe some super glue on a small dowel or two if you greased them they should slip right out
Post by midlifecrisisrd on Feb 19, 2019 17:34:44 GMT 1
Pull the castle seal out and try and get a grip on the inner face with some circlip pliers
Check the new inner size with the old one
Post by philmill on Feb 19, 2019 17:37:16 GMT 1
Done! Glad it’s was nicely lubed 😉
Post by philmill on Feb 19, 2019 17:40:01 GMT 1
So while we are on the subject. The cables I got are both the same, I’m sure I saw a genuine one with an adjuster in the actual cable rather then just on the pulley end, so are there right?
Post by stusco on Feb 19, 2019 17:41:36 GMT 1
That would have been Steve’s custom jobbies yours are correct
Post by midlifecrisisrd on Feb 19, 2019 17:41:51 GMT 1
They are right
Even the genuine cables have the same part number
It was my cables from mutts that had adjusters in the middle
Post by philmill on Feb 19, 2019 17:53:43 GMT 1
Cool, that’s great, thanks Steve. They do seem short, one is quite tight once it’s in place. But I guess it’ll be ok.
Post by oldbritguy on Feb 21, 2019 11:23:23 GMT 1
Looking good Phil. Glad you brought this up as I have new bushes to fit when the cylinders come back. I'll look out for this1
J
