Post by marrcel on Feb 18, 2019 20:17:14 GMT 1
It is leaking again😤 I used an o ring i found in the shed. May be only suitable for water. Anyway i get another oil resistant one. I am looking for the correct diameter and thicknes in mm. Thanks in advance.
Post by dusty350 on Feb 18, 2019 20:28:42 GMT 1
Why not get a genuine Yamaha item ? Only £3.00 - 93210 29196 Fowlers have them in stock. Dusty
Post by Tobyjugs on Feb 18, 2019 20:46:53 GMT 1
Why not get a genuine Yamaha item ? Only £3.00 - 93210 29196 Fowlers have them in stock. Dusty Genuine parts in Holland are available in Holland but it can take a while. It can be very quick or very slow to receive parts from the UK. Its like lucky dip with the postal service. Today i received an order of genuine gearbox shims and circlips etc from CMSNL. I ordered the parts on the 24-01-19.
Post by midlifecrisisrd on Feb 18, 2019 21:02:05 GMT 1
Why not get a genuine Yamaha item ? Only £3.00 - 93210 29196 Fowlers have them in stock. Dusty Genuine parts in Holland are available in Holland but it can take a while. It can be very quick or very slow to receive parts from the UK. Its like lucky dip with the postal service. Today i received an order of genuine gearbox shims and circlips etc from CMSNL. I ordered the parts on the 24-01-19. I find this hilarious as when we order parts from Yamaha that are out of stock we get them from Holland 🤣 Steve
Post by Tobyjugs on Feb 18, 2019 21:14:21 GMT 1
Genuine parts in Holland are available in Holland but it can take a while. It can be very quick or very slow to receive parts from the UK. Its like lucky dip with the postal service. Today i received an order of genuine gearbox shims and circlips etc from CMSNL. I ordered the parts on the 24-01-19. I find this hilarious as when we order parts from Yamaha that are out of stock we get them from Holland 🤣 Steve So it's all the fault of the Brits jumping the que!!!
Post by midlifecrisisrd on Feb 18, 2019 21:18:21 GMT 1
I find this hilarious as when we order parts from Yamaha that are out of stock we get them from Holland 🤣 Steve So it's all the fault of the Brits jumping the que!!! Must be lol If we order stuff from a Yam dealer if in stock is next day If it needs to come from Europe it's usually 3 - 4 days Steve
Post by headcoats on Feb 18, 2019 21:57:38 GMT 1
I tried one of those orange oversized 0 rings that go on the power valve collars and seemed to fit , but haven't tried it on engine LOL
Post by marrcel on Feb 19, 2019 11:46:09 GMT 1
Thanks guys but ordering online i do when i have say ten items or so. But a single seal or bearing i go to a shop near by. Motorenco. This is easier for me. So i am still looking for the correct size. If someone has one. Could you measure it for me please?
Post by Tobyjugs on Feb 20, 2019 16:25:09 GMT 1
I opened 3 different covers for 3 different surprises ha ha. i would go for an O-ring with 30 mm (maybe 29.5 mm) Inside diameter 2.25 mm thick. Normally they measure the O-ring by dropping it over a graduated cone. if it's a problem let me know
Post by marrcel on Feb 20, 2019 17:22:42 GMT 1
Thank you very much Tony. I will let you the result of it. Cheers
Post by Tobyjugs on Feb 22, 2019 12:55:24 GMT 1
Thank you very much Tony. I will let you the result of it. Cheers I took the best O-ring and dropped it over a cone it measured 29 mm ID and 2.5 mm thick using the guage. I managed to get a few so if you haven't got one I have one for you. Tonight I will check if it fits.
Post by marrcel on Feb 27, 2019 8:42:00 GMT 1
This is what i bought.
Post by marrcel on Feb 27, 2019 16:58:40 GMT 1
First one fitted. But i cant test. Still waiting on brass bals😤
Post by Tobyjugs on Feb 27, 2019 20:48:58 GMT 1
First one fitted. But i cant test. Still waiting on brass bals😤 If it's filled up with oil and doesn't leak it's good
