Post by shaunthe2nd on Feb 16, 2019 14:27:20 GMT 1
I'm well on with a 350LC 4L0 build. Just about everything has been done and getting ready to put in engine/carbs/exhausts but I have an electrical problem on the rolling chassis.
The bike came with a new loom. It looks original but could be a copy as I had to swap over 2 connectors which weren't right.
I have fitted and wired up all the electrical devices, put in a battery and it seems that most things work, BUT the rear left indicator remains on.
Whilst investigating this problem, it appear that even if i remove all 4 fuses from the box, pretty much everything still works! This I suspect is my real problem, the indicator lighting up is probably a symptom.
I have swapped a lot of parts over with others from a working bike including the indicators, flasher unit, clocks, switch gear, regulator, front and rear brake switches, rear light assy, etc but the problem remains, so I suspect its down to the wiring loom?
I have cleaned and re-tapped the earth point next to the coil, but again, most items work with or without this earthwire connected.
Anyone had something similar or any suggestions where to look?
All help appreciated, thanks, Shaun.
Post by 4l04ever on Feb 16, 2019 14:47:09 GMT 1
I have a good quality colour scan of the wiring diagram I can send you. pm me your email address.
Does the power stay on all the time?
Post by earthman on Feb 16, 2019 17:24:35 GMT 1
I'm guessing that something could be a miss with the whole fusebox set up for a start? Removing all fuses and still getting power sounds like either it's not been wired correctly or there's a short somewhere, maybe the main + feed from the battery is finding another path? How odd, interested to know the actual cause.
Post by 4l04ever on Feb 16, 2019 19:44:49 GMT 1
I have spoken with Shaun on the phone. Seems to be a wiring/loom issue as appears to be a pattern loom. I remember some pattern ones which had a few different connectors, so could be one of those.
On Shaun's bike, the fault appears to be that there is a connection made between the red wire coming from the battery + to the top of the main fuse, and to the red wire coming out of the bottom of the main fuse in the loom, so Shaun will strip the loom back from the battery + to the fuse box to find the join/short.
Post by muttsnuts on Feb 16, 2019 20:01:47 GMT 1
ignition switch faulty or wrong one fitted?
Post by 4l04ever on Feb 16, 2019 20:55:33 GMT 1
Power fault still evident with ignition switch unplugged and reg/rec unplugged. Main fuse out, and power is still on both main fuse terminals.
Post by 4l04ever on Feb 16, 2019 20:58:32 GMT 1
The issue is only in the red wires. Brown wire does not go live.
Post by shaunthe2nd on Feb 17, 2019 21:14:51 GMT 1
Thanks Rob and Dave for some help. Hopefully I have now solved it with your input. It seems to be a problem with mis-wiring within the loom. I wanted to be sure it wasn't any of he electrical components before I dissected the loop.
Rob (4l04ever) talked me through some possibilities, and by elimination I found the problem and does appear to be a fault within the loom. It was wired to put 12v on both sides of the main fuse rendering the fuse useless.
I have now temporary rectified with twisted connections and over the next few days will re-solder and re-wrap the loom. I like to take my time for that.
From this i can summarize it must have been a copy loom, i purchased this on ebay some 3+ years ago and never used, and also had to change over 2 connector blocks which weren't correct. Apart from that its been great.
The decision to re-use an old proven loom or use a new copy one is marginal! Lol.
Thanks for the help guys. Shaun
Post by shandyboy on Feb 26, 2019 0:07:36 GMT 1
Shaun I have a genuine NOS loom in the packet let me know if you need photos of it to compare with yours Buddy ??
Alan
Post by shaunthe2nd on Feb 26, 2019 21:49:58 GMT 1
Shaun I have a genuine NOS loom in the packet let me know if you need photos of it to compare with yours Buddy ?? Alan Alan thanks for that offer but you would have to unwrap the loom to show me what I needed to see as it ended up the wiring and not the connectors. The main fuse was wired in parallel rendering it useless and one if the rear indicators was permently live too! I figured it out in the end but had to unwrap half of it to sort it. It's all sorted now but thanks for you kind offer cheers.
Post by shandyboy on Feb 26, 2019 22:52:56 GMT 1
No Worries Shaun
