Post by kevrev1 on Feb 7, 2019 21:57:07 GMT 1
Anyone successfully got a factory finish on their 4L0 footrest hangers and lower fork legs? If so what process did you follow? Thanks
Post by bezzer on Feb 8, 2019 8:03:56 GMT 1
Hi, Assuming you’re after a standard look?, I used red scotchbrite on my lower fork legs, it gives the ‘factory, brushed’ appearance, then clear lacquer to protect. This tip was given to me by another forum member, and worked really well for me. One thing to note is it MUST be the red scotchbrite, green is too coarse and the grey gives a polished finish. Hope that helps.
Post by kevrev1 on Feb 8, 2019 8:13:24 GMT 1
Thats great thanks, i assume that would work for the hangers as well
Post by stusco on Feb 8, 2019 8:20:51 GMT 1
If you get them vapour blasted first they come up really well ,I don’t lacquer them though I just spray them with acf 50
Post by copper99 on Feb 8, 2019 17:49:48 GMT 1
I used green scotchbrite pads with GT85...They have come up very nicely indeed..
Post by jon on Feb 8, 2019 19:47:00 GMT 1
If you get them vapour blasted first they come up really well ,I don’t lacquer them though I just spray them with acf 50 +1 Almost polish them first with fine wet and dry. Instead of mopping the last bit use red scotchbrite for the finish. ACF 50 is good to keep this finish. Jon
Post by Gunny on Feb 10, 2019 15:44:56 GMT 1
Post by Gunny on Feb 10, 2019 15:46:31 GMT 1
Post by kostas on Feb 10, 2019 18:18:08 GMT 1
