Nuts!
Feb 4, 2019 16:16:36 GMT 1
via mobile
Post by skint on Feb 4, 2019 16:16:36 GMT 1
Hi all, anyone have any suggestions how to undo the nut holding the primary drive/main gear on at the end of the crank safely? (Crank is out) Also, anyone have a spare gear with 95 scribed on it as mine has 79. Don't know what it's from but obviously the wrong one. Cheers Paul.
Nuts!
Feb 4, 2019 16:27:33 GMT 1
via mobile
Post by midlifecrisisrd on Feb 4, 2019 16:27:33 GMT 1
Clamp the end journal in a vice (without clamping the other 3 journal and supporting the rest of the crank and undo the nut
Nuts!
Feb 4, 2019 16:29:24 GMT 1
via mobile
skint likes this
Post by kostas on Feb 4, 2019 16:29:24 GMT 1
If your crank is out then I would suggest that you take it to a local garage and have it undone with an air driven rattle gun.
That’s it if you don’t have one yourself.
Kostas
Nuts!
Feb 4, 2019 17:00:44 GMT 1
Post by stusco on Feb 4, 2019 17:00:44 GMT 1
Hi all, anyone have any suggestions how to undo the nut holding the primary drive/main gear on at the end of the crank safely? (Crank is out) Also, anyone have a spare gear with 95 scribed on it as mine has 79. Don't know what it's from but obviously the wrong one. Cheers Paul. There will be a number engraved on the gear on you clutch basket if you add them they should come to 155
Nuts!
Feb 4, 2019 17:01:05 GMT 1
via mobile
Post by skint on Feb 4, 2019 17:01:05 GMT 1
Clamp the end journal in a vice (without clamping the other 3 journal and supporting the rest of the crank and undo the nut Steve Sorry mate, what's a journal? Cheers.
Nuts!
Feb 4, 2019 17:02:37 GMT 1
via mobile
Post by skint on Feb 4, 2019 17:02:37 GMT 1
Hi all, anyone have any suggestions how to undo the nut holding the primary drive/main gear on at the end of the crank safely? (Crank is out) Also, anyone have a spare gear with 95 scribed on it as mine has 79. Don't know what it's from but obviously the wrong one. Cheers Paul. There will be a number engraved on the gear on you clutch basket if you add them they should come to 155 Mine come to 139!
Nuts!
Feb 4, 2019 17:04:13 GMT 1
Post by stusco on Feb 4, 2019 17:04:13 GMT 1
Well use the one with 95
Nuts!
Feb 4, 2019 17:06:30 GMT 1
via mobile
skint likes this
Post by midlifecrisisrd on Feb 4, 2019 17:06:30 GMT 1
Clamp the end journal in a vice (without clamping the other 3 journal and supporting the rest of the crank and undo the nut Steve Sorry mate, what's a journal? Cheers. The big round bits the con rods go between Steve
Nuts!
Feb 4, 2019 17:57:45 GMT 1
via mobile
Post by skint on Feb 4, 2019 17:57:45 GMT 1
I would if I had one, that's what I'm after. My clutch basket is scribed 60 and gear scribed 79.
Post by stusco on Feb 4, 2019 18:00:08 GMT 1
I should learn to read
Post by dusty350 on Feb 4, 2019 18:12:31 GMT 1
You can also go with 94 or 96 as it's 155 +/- 1, so 154, 155 or 156 Dusty
Post by 4l04ever on Feb 4, 2019 19:10:25 GMT 1
You can use a 12V impact gun to undo or tighten the crank nut.
Nuts!
Feb 4, 2019 20:12:28 GMT 1
via mobile
skint likes this
Post by 0h5h1t on Feb 4, 2019 20:12:28 GMT 1
If you're close enough you can pop the crank round and I'll gun it off for ya. I'm near Harlow, Essex.
Post by Yogi on Feb 4, 2019 20:35:31 GMT 1
If you’re nearer Clacton I’ll gun it off for ya
Nuts!
Feb 4, 2019 21:55:00 GMT 1
via mobile
Yogi likes this
Post by skint on Feb 4, 2019 21:55:00 GMT 1
Typical! I'm in Halstead so pretty much in between the pair of you. Really kind offer from both of you but I'm going to pop down a local garage tomorrow and see if they can do the same. I've tried the journal in the vice but I can't budge it! Good to learn that a couple of you guys are pretty close though. Cheers Paul.
Nuts!
Feb 5, 2019 16:20:08 GMT 1
via mobile
Yogi likes this
Post by skint on Feb 5, 2019 16:20:08 GMT 1
Air gun did the job! Cheers chaps. Paul.
Nuts!
Feb 5, 2019 20:33:01 GMT 1
via mobile
Post by skint on Feb 5, 2019 20:33:01 GMT 1
You can also go with 94 or 96 as it's 155 +/- 1, so 154, 155 or 156 Dusty How important is it being +/- 1 as I've been offered a 93 which would make it 153. What are the consequences of not being 155? Cheers Paul.
Post by dusty350 on Feb 5, 2019 20:49:26 GMT 1
I've asked the same question before. The backlash is the clearance between the teeth as the come together. You need the clearance for lubrication, and expansion due to heat from running. The gears in our bikes are getting on for 40 years old so you would imagine that the backlash they left the factory with probably wont be the same now, due to wear and tear over the years. But I was keen to keep it as per Yamaha intended, and fitted a 94 needed for 155 instead of the 91 I had. Worst case scenario I suppose would be gears that jam together but I would think they would need to be wildly out for that to happen ? Maybe the engineering guys on here can shed some light ? Dusty
Nuts!
Feb 11, 2019 9:38:23 GMT 1
via mobile
Post by midlifecrisisrd on Feb 11, 2019 9:38:23 GMT 1
You can also go with 94 or 96 as it's 155 +/- 1, so 154, 155 or 156 Dusty How important is it being +/- 1 as I've been offered a 93 which would make it 153. What are the consequences of not being 155? Cheers Paul. Considering it ran with a 79 in it I think 1 out is fine As Dusty says there will be wear anyway so backlash will be bigger anyway Steve
Nuts!
Feb 11, 2019 9:50:42 GMT 1
via mobile
Post by Tobyjugs on Feb 11, 2019 9:50:42 GMT 1
I measure the clearance of the primary gears at correct and incorrect numbers and it does not follow any particular pattern. I'm starting to think maybe it's to do with the helix angle and the contact patch. I do have some special paint to test this idea, but as of yet not done.
