Post by dusty350 on Jan 31, 2019 23:36:06 GMT 1
I know a few members here bought from the latest batch of Lc swingarms made by Metmachex. I've had an issue with mine and wondered if anyone else has too. I'm trying to gauge numbers so I can inform Tamsyn at Metmachex as they didn't realise that some of their sizings were wrong. Basically, my Lc arm was slightly too narrow to fit in the frame. I didn't give it much thought at the time, and used some washers I had as shims and it was fine. I also ordered an Lc arm for an Rgv wheel and that arrived recently. There was a fair gap this time. Where the swingarm bolts to the frame. An Lc measures 200mm across this pivot point. My arm measured 196mm, so I had a 4mm gap.I measured 3 Lc standard arms - all 200mm with end caps, so the Met arm was definitely narrow. Metmachex measured one of the arms they have in stock, and its 199.90mm, which would be correct. They've supplied 2 x 1mm shims so far, but I still need another 2. I just wondered if anyone else that bought recently had this issue ?? Dusty
Post by icarus001 on Feb 1, 2019 4:28:23 GMT 1
Looks like they've measured without the end caps? Then not tried them in an actual bike and just sent them out?
That's not great for something that expensive.
Post by Trubrit on Feb 1, 2019 7:54:46 GMT 1
Hey Dusty
I Had To Pinch 2 Shims Out Of Another Arm I Had To Make Mine Fit Snug . I Just Thought it Was My Frame That Was Out Of Tolerance Slightly .
Dave
Post by dusty350 on Feb 1, 2019 8:06:46 GMT 1
Post by beardy on Feb 1, 2019 8:14:45 GMT 1
not the same as your issue but it is to do with not fitting correctly. i bought my arm back in the early 80`s and the 2 vertical uprights rubbed against the inner mudguard when i sat on the bike.
Post by beardy on Feb 1, 2019 8:15:01 GMT 1
Post by Trubrit on Feb 1, 2019 8:32:31 GMT 1
Im Pretty Sure They Were 1mm , Basically The Same Shims From Another Metmachex Arm , Nice Fit Then Even When The Frame Was Powdered . Dave
Post by dusty350 on Feb 1, 2019 8:54:25 GMT 1
Cheers Dave Dusty
Post by Dangerous on Feb 1, 2019 9:23:42 GMT 1
Morning Dusty. Just popped out to freezing man cave after reading this, checked my arm and i have no gap at all. Sorry to hear yours isnt right.🤔
Post by midlifecrisisrd on Feb 1, 2019 10:31:58 GMT 1
Might be a good thing as there must be a tolerance on the frames
When I fitted my nk adapted banana arm I had to use a rubber mallet
Fine now it's in but a Bugger to fit.
Don't know if it's helpful but F/N/R ypvs have shims under the end caps, can check the size if anyone wants
Post by mouse on Feb 1, 2019 10:38:35 GMT 1
Hope you get a satisfactory result on this Dusty, they have clearly made a mistake!
ATB Mouse
Post by steven on Feb 1, 2019 12:58:16 GMT 1
Looks like they've measured without the end caps? Then not tried them in an actual bike and just sent them out? That's not great for something that expensive. +1 Steven.
Post by 4l04ever on Feb 1, 2019 13:49:54 GMT 1
Being undersize is not a bad thing, as some people may have a frame that is squashed in. Perhaps offering shims to suit would be a good option.
Post by oldelsieboy on Feb 1, 2019 14:48:34 GMT 1
I purchased 2 arms recently, the first fitted perfectly, a nice snug fit. The second was approx 3mm narrow & after spending £6.50 on a selection of shims from eBay it now fits fine.
OEB
Post by bazzer5115 on Feb 1, 2019 15:02:07 GMT 1
A couple of shims ,and when you tighten it up the frame will pull in. I had a gap similar to yours,when fitting a SZR660 arm to ypvs frame in my air cooled hybrid and I machined to much off the bearing tube(my mistake,silly old fool)so that what I did.👍
Post by barney on Feb 1, 2019 17:08:59 GMT 1
I know a few members here bought from the latest batch of Lc swingarms made by Metmachex. I've had an issue with mine and wondered if anyone else has too. I'm trying to gauge numbers so I can inform Tamsyn at Metmachex as they didn't realise that some of their sizings were wrong. Basically, my Lc arm was slightly too narrow to fit in the frame. I didn't give it much thought at the time, and used some washers I had as shims and it was fine. I also ordered an Lc arm for an Rgv wheel and that arrived recently. There was a fair gap this time. Where the swingarm bolts to the frame. An Lc measures 200mm across this pivot point. My arm measured 196mm, so I had a 4mm gap.I measured 3 Lc standard arms - all 200mm with end caps, so the Met arm was definitely narrow. Metmachex measured one of the arms they have in stock, and its 199.90mm, which would be correct. They've supplied 2 x 1mm shims so far, but I still need another 2. I just wondered if anyone else that bought recently had this issue ?? Dusty Mine is the same as yours and am going to have to get some shims made up I spoke to Nigel at nk and he said to try to achieve 199.5mm overall it is a bit of a pain as it’s a real a.lach for me as I don’t have any facilities to measure it properl so will have to take it somewhere
Post by risolc on Feb 1, 2019 18:11:17 GMT 1
Mine didn’t fit either,just got some shims off eBay,thought it was all part & parcel of fitting after market parts. The hassle I’m having trying to fit Tarozzi rear sets😡.
Post by headcoats on Feb 1, 2019 18:15:13 GMT 1
A bit loose is way better as getting a tight one in is a right bugger !
Post by dusty350 on Feb 1, 2019 18:59:04 GMT 1
Hi Yea, I agree, loose is better and then use shims, but until I pointed it out they thought all the arms were the same width (199.90) which obviously they aren't. I'm not moaning about it, just trying to gauge how many are loose and how many aren't, as theoretically, they should all be exactly the same. I wonder if they have had a batch of pivot tubes that are slightly too short ? Dusty
Post by stusco on Feb 1, 2019 19:17:04 GMT 1
Mine didn’t fit either,just got some shims off eBay,thought it was all part & parcel of fitting after market parts. The hassle I’m having trying to fit Tarozzi rear sets😡. I had to make 10mm spacers to make my Tarozzi rear sets fit
Post by veg on Feb 1, 2019 19:46:32 GMT 1
Mine didn’t fit either,just got some shims off eBay,thought it was all part & parcel of fitting after market parts. The hassle I’m having trying to fit Tarozzi rear sets😡. 😁😁😁 that’s why no one has them I had a set and just fecked them into the bin shockingly shite Sorry don’t mean to gloat but they are pretty crap
Post by johnlam on Feb 1, 2019 20:12:23 GMT 1
Sorry but Yamaha made thousands all to a close tolerance , ok you can shim but the amounts being talked about are ott.Cranking the spindle to pull in frame NO, that is a bodge . John
Post by JonW on Feb 2, 2019 2:15:04 GMT 1
I think its good you asked the question Dusty, plenty of people will have bought these and stuck them on top of their wardrobes and other storage spots for when they build that project, few will have test fitted them.
Post by 1966baz on Feb 2, 2019 9:48:34 GMT 1
I've had a perfect fit with JMC arms on my marsbar and Z1100R. With Metmachex however I had to machine down the spindle a small amount to fit my Z1000j (back in 1988 ish) and the chain kept hitting the top of the lower brace. Obviously Metmachex have come on a lot and look beautiful well made arms but at over £600 surely they should be pretty spot on. Saying all this whenever I've fitted after market parts to 80's bikes there has always been some minor adjustments to get everything to fit.
Post by yamman1066 on Feb 2, 2019 11:47:10 GMT 1
Hi I have 2 new s,arms £500 and £700 both 4mm small Hoping there sending shims out to sort it I also have the 80s arm that’s spot on
Post by lb on Feb 4, 2019 8:39:33 GMT 1
Mine was at 198mm with the seal/spacer in place. Need to make some shims...
Post by peter007 on Feb 4, 2019 9:04:11 GMT 1
I've just been looking at these arms and for what they cost id be very disappointed if they were so poorly made and have such big gaps . but im sure if they knew they'd rectify there tooling ? but then again where's the quality control ? each one should be checked surely ? just my two penneth . Pete
Post by metmachexswingarms on Feb 4, 2019 15:31:52 GMT 1
Good Afternoon, Just to let you all know it has come to light that we need to send out shims to all that last ordered the LC Swingarms. I will go through the list and ensure I send some out. Apologies for any inconvenience and thanks to Dusty for bringing this issue to our attention. Regards Tamsyn Metmachex Swingarms LTD
Post by Yogi on Feb 4, 2019 17:29:30 GMT 1
At least metmachex are doing the right thing now they know
Bellend(Legend) motorcycles just blocked me on eBay when I asked for a new knuckle to replace it on there crap billet kickstart which fell off after two kicks
Post by bare on Feb 4, 2019 18:11:42 GMT 1
Too little? Too late? These are EXPENSIVE arms. Likely not much wrong with the quality control of the Coin traded for the product
