Post by tomitch on May 4, 2009 22:02:31 GMT 1
does any body have the dimensions of the 25/350 lc/ypvs in let rubbers im curious about fitting one to my 125lc so i can shove a bigger carb on there or is there one that fits ??
Post by twostroker on May 4, 2009 22:39:56 GMT 1
does any body have the dimensions of the 25/350 lc/ypvs in let rubbers im curious about fitting one to my 125lc so i can shove a bigger carb on there or is there one that fits ?? apperently 250,350lc carb rubbers fit but theres no much point as the standard 125lc carb rubber is perfect for a nice 28mm flatslide,try find one off a tzr250 or kr1s,failing that a 28mm round slide from a rd400 is ment to be a good upgrade.i run a pwk28 from a kris thats been machined out to 29.5mm and the throttle response is far better than standard,only downside is it would be tricky to make a cable up to run auto lube at the correct mixtere,i just run pre-mix
Post by tomitch on May 5, 2009 10:20:06 GMT 1
ahh right cheers i only run premix anyway i made a blanking plate for my oil pump
Post by twostroker on May 5, 2009 19:20:46 GMT 1
if you want another good mod is fit the complete reed cage,inlet rubber and 32/34 mm carb from a yz125,the barrel will require some engineering on the inlet side and to make the most of it you would have to run crazy ports and a matched expansion chamber but it would be possable to produduce big power for a 125 or 175,the easy route is just to fit a 28mm flat side like i did but mine is only mildly ported,depends how far you want to go,idealy a good pipe is the most important bit
Post by tomitch on May 10, 2009 18:08:01 GMT 1
yer tbh i think ill just stick to the 28mm flatty for now as my bike is my transport, and im pretty skint as per, lol but i think it could be a good modification for the future would like to give it a go especially now iv got the bigbore sorted, i can see how it goes next week just resprayed my frame and wheels
Post by twostroker on May 10, 2009 19:56:01 GMT 1
yer tbh i think ill just stick to the 28mm flatty for now as my bike is my transport, and im pretty skint as per, lol but i think it could be a good modification for the future would like to give it a go especially now iv got the bigbore sorted, i can see how it goes next week just resprayed my frame and wheels any problems give me a shout mate,ive done my fair shair of big bore stuff,make sure you set the fueling rich and work down,if you go for a pwk carb your jetting will be similar to mine
Post by tomitch on May 10, 2009 20:47:23 GMT 1
haha i had the fueling problem last time iv got an rgv250 tap on now, i think ill start around 260 main jet see how it goes from there i was runnin a 300 with a squish of about 2.4-2.8mm. PJ machined my barrel down for me ( i did ask for a rebour but they just honed it instead ) so my squish is around 1.1-1.2mm so ill see how it goes. cheers for the help twostroker
Post by twostroker on May 10, 2009 20:58:30 GMT 1
my pwk 28 runs a standard main (135 i think) and one size down on the pilot jet.
Post by racerd on May 26, 2009 16:18:28 GMT 1
squish set to under 1mm
