Post by philmill on Jan 18, 2019 17:43:04 GMT 1
Hi guys, so I fitted the stator today and a few other bits, I wonder if anybody has pics showing the location of the plugs from the CDI etc, also, I think there should be a clamp on top of the crankcase somewhere, I can figure kind of where it should all go, but some pics would be handy. My loom and wiring is a bit hard now so I don't want to be forcing anything in case it cracks.
Thanks, Phil
Post by panzermatt on Jan 18, 2019 18:13:46 GMT 1
check out my 31k rebuild plenty of pics there, however if you need more ill take some
Post by midlifecrisisrd on Jan 18, 2019 19:00:04 GMT 1
Hi guys, so I fitted the stator today and a few other bits, I wonder if anybody has pics showing the location of the plugs from the CDI etc, also, I think there should be a clamp on top of the crankcase somewhere, I can figure kind of where it should all go, but some pics would be handy. My loom and wiring is a bit hard now so I don't want to be forcing anything in case it cracks. Thanks, Phil The stator wiring should go across the casing to the right hand rear corner then up the side of the battery box The clamp that holds the clutch cable onto the top case should have a wire loop on it that holds the cable down Steve
Post by midlifecrisisrd on Jan 18, 2019 19:07:28 GMT 1
You can see the clip and route here Steve
