Post by philmill on Jan 16, 2019 20:10:12 GMT 1
Hi guys, I have been looking for ideas and used the search function like a good boy , but can't find much info. So what options do I have for the Rear Master Cylinder other than the original item, I am using std footrest plates and RGV calliper. Also, other than the tube set up is there any other ideas for the reservoir? I've dragged the bike out and started playing again, its been a while since I did anything to it. Phil
Post by philmill on Jan 16, 2019 20:12:26 GMT 1
Oh, its an LC2!!
Post by midlifecrisisrd on Jan 16, 2019 21:35:21 GMT 1
Sure it's an r6 that has the same fitment as std but is brembo 😎
Post by 4l04ever on Jan 16, 2019 22:56:40 GMT 1
Post by JonW on Jan 17, 2019 1:30:05 GMT 1
Im all for trick stuff, but the original is the same bore size as most others mentioned, why not just use that as it fits the bike etc?
Post by mouse on Jan 17, 2019 8:40:12 GMT 1
Post by midlifecrisisrd on Jan 17, 2019 10:25:23 GMT 1
Good info, I've just used a ypvs rod before but this solves that It wasn't you that found the convertors for clip ons to standard bars was it? Steve
Post by philmill on Jan 17, 2019 10:28:42 GMT 1
Mouse, I like that, no reservoir either which is nice, so is that a straight swap, are your footrests YPVS ones? what does it fit?
Jon, I take your point, but my master cylinder is seized so if I'm changing I may as well put something nice on, the rest of the bike is far from std.
Phil
Post by midlifecrisisrd on Jan 17, 2019 10:29:58 GMT 1
Im all for trick stuff, but the original is the same bore size as most others mentioned, why not just use that as it fits the bike etc? Its not about the brembo one being trick for me because as you say they are same fitment and bore size Yes A little bit of bling as it has "Brembo" on it but that's just like polished over painted The main attraction to me is that it is anodised rather than painted so not a blistered or painted mess that needs refurbing or as has been the case on the last couple of bikes I've bought seized solid Steve
Post by JonW on Jan 17, 2019 12:18:23 GMT 1
I hear you Steve, Ive refubed so many of these its got to be silly and they seem to be arriving in worse condition every time. One thing tho, these were fitted to many Yams and can be found more modern than the 80s so in better nick etc.
I have the Brembo unit on my XT500, its a nice compact unit if you get the one with the correct orientation fittings so good for space issues like on that bike, XT5s are silly small, like moped sized.
Post by mouse on Jan 17, 2019 14:07:44 GMT 1
Mouse, I like that, no reservoir either which is nice, so is that a straight swap, are your footrests YPVS ones? what does it fit? Jon, I take your point, but my master cylinder is seized so if I'm changing I may as well put something nice on, the rest of the bike is far from std. Phil Hi Phil The footrests are NK rearsets. I am pretty sure all the Brembo Master Cylinders have the same hole centres, as i had a normal one on before with these rearsets. If you like I can measure the hole centre distance? Mouse
Post by philmill on Jan 17, 2019 14:25:03 GMT 1
Thanks Mouse, no its fine, as you say, if you had the std one then it must fit. I can measure my frame.
Thanks again, Phil
Post by dusty350 on Jan 17, 2019 19:21:51 GMT 1
Hi Phil The standard Pv master has a top mounting as well as a side mounting so different to Mouse's. Like this; 20150616_102820 by dusty miller, on Flickr Dusty
Post by midlifecrisisrd on Jan 17, 2019 19:35:02 GMT 1
Im all for trick stuff, but the original is the same bore size as most others mentioned Just had another thought on this Jon Is the standard one 1/2 inch? The Brembo's are 14mm Steve
Post by jon on Jan 17, 2019 19:44:58 GMT 1
Mouse, I like that, no reservoir either which is nice, so is that a straight swap, are your footrests YPVS ones? what does it fit? Jon, I take your point, but my master cylinder is seized so if I'm changing I may as well put something nice on, the rest of the bike is far from std. Phil Ive just put my seized rear master cylinder in an minutes it was free. A Tourmax (Probably OEM) kit for around £20 not only comes with new seals etc, but also a nice new zinc plated plunger so it can be made to look like new for very little money. Jon
Post by jon on Jan 17, 2019 19:46:35 GMT 1
Im all for trick stuff, but the original is the same bore size as most others mentioned Just had another thought on this Jon Is the standard one 1/2 inch? The Brembo's are 14mm Steve Steve I think some of the Brembo’s are 1/2”. For instance TZR 250 ones. Jon
Post by midlifecrisisrd on Jan 17, 2019 19:55:39 GMT 1
Just had another thought on this Jon Is the standard one 1/2 inch? The Brembo's are 14mm Steve Steve I think some of the Brembo’s are 1/2”. For instance TZR 250 ones. Jon Ah right The one I have is 14mm Steve
