Post by splodgey on Jan 13, 2019 23:28:17 GMT 1
What make of inner tubes should I buy. The tyres on my 250 LC seem to loose air on a weekly basis. I had new tyres fitted but I think they fitted cheap tubes. Any advise would be welcome. Thanks, Dave W
Post by 4l04ever on Jan 13, 2019 23:30:16 GMT 1
Get a decent brand like Michelin.
Post by mattybeckett on Jan 14, 2019 0:12:37 GMT 1
+1 Michelin π
Post by shaunyb63 on Jan 14, 2019 5:25:06 GMT 1
Had some Avon roadriders fitted on mine recently at National Tyres in Barnsley and they only fit Michelin tubes,and they do seem to hold pressure well.
Post by Dangerous on Jan 14, 2019 6:15:15 GMT 1
Same as above.πππ
Post by earthman on Jan 14, 2019 9:00:00 GMT 1
I have a heavy duty Pro Air one on my rear wheel, it's holding air OK. I'm looking at it's twin right now, it's got ISO 9001:2008 printed on it.
It had been a long time since I had a bike with tubes so I just looked on ebay for heavy duty and twin pack.
Post by shaunthe2nd on Jan 14, 2019 10:33:56 GMT 1
I assume it is the valve that leaks, rather than the rubber itself, so might be worth changing the valve first for a decent one to see if that improves things.
Post by earthman on Jan 14, 2019 12:12:25 GMT 1
I assume it is the valve that leaks, rather than the rubber itself, so might be worth changing the valve first for a decent one to see if that improves things. Good point about the valve, it's worth checking that out but I gather that inner tubes just aren't that great at retaining air pressure period. Going by my own experience, tubeless tyres drop less psi over a longer time span too.
Post by splodgey on Jan 14, 2019 21:47:40 GMT 1
Thanks for all this advise. I have found some michelin tubes on e bay and like the look of them. I think it is the poor rubber that just leaks air and not the valve.
Post by mattybeckett on Jan 15, 2019 0:16:54 GMT 1
Thanks for all this advise. I have found some michelin tubes on e bay and like the look of them. I think it is the poor rubber that just leaks air and not the valve. Did you try a bit of spit on the valve just to be sure π€
webbo
Post by webbo on Jan 15, 2019 14:27:22 GMT 1
Hi Just a thought but are you sure they fitted tubes? It has been known to fit tubeless tyres without tubes because itβs been assumed itβs correct on cast wheels. Cheers.
