Post by dusty350 on Jan 12, 2019 23:07:11 GMT 1
Post by wallcraft on Jan 12, 2019 23:15:36 GMT 1
Good spot. Good idea. These are are the sort of engineering alternatives I like, wish I had an engineering back ground to execute them.
Mark.
Post by headcoats on Jan 12, 2019 23:17:37 GMT 1
I like it and seeing how much the gear shafts cost now, a good solution
Post by midlifecrisisrd on Jan 13, 2019 0:07:04 GMT 1
That thought had passed through my head
Good that someone has made I'd
Post by Gunny on Jan 13, 2019 11:01:32 GMT 1
Saw the guy that makes them posting on a facebook group last night, seems a good idea, and hes not being greedy with the price either
Post by Deleted on Jan 13, 2019 13:56:49 GMT 1
will it fit a 31k, does any one know, if so even more useful
Post by dusty350 on Jan 13, 2019 15:23:57 GMT 1
The seal for the Lc and the pv is the same part number so I would imagine it should fit. Dusty
Post by earthman on Jan 13, 2019 16:02:11 GMT 1
Great to see other options to such problems, anyone going to try it out?
Post by doohanno1 on Jan 13, 2019 16:16:51 GMT 1
This would be ideal for a numbty like me who went to the trouble of getting the groove welded up and dressed on the shaft and then did nothing with the casing..😩
Post by mikee on Jan 13, 2019 16:29:20 GMT 1
Been doing that mod for years Mike
Post by headcoats on Jan 13, 2019 16:54:12 GMT 1
Shave a few mm off to keep moving the seal and have a gear selector shaft for life !
Post by copper99 on Jan 13, 2019 18:08:18 GMT 1
I think Stan Stephens knocked up something similar up and talked about it in one of his articles, its a fab idea anyway and will hopefully save many people the time/money of rebuilding an engine to correct it.
Post by bare on Jan 13, 2019 19:09:55 GMT 1
In the Ebay advert the Neutral switch cover was cracked. Wondering IF that oil leak... was misdiagnosed as a clutch shaft leak ?
dbgr
Post by dbgr on Jan 13, 2019 19:21:54 GMT 1
Hi Mikee,excellent engineering, don't suppose you would do me a gear lever modification would you?
Post by 4l04ever on Jan 13, 2019 21:03:39 GMT 1
The kit an Ebay could be even better if he made it slightly wider so a double lip seal could be used.
Post by rigga on Jan 13, 2019 21:16:41 GMT 1
You'd need to shorten the nylon spacer between the crankcase and the outer cover no?
Post by dusty350 on Jan 13, 2019 21:17:45 GMT 1
You would, or use a Pv sleeve which is shorter anyway. Dusty
Post by mikee on Jan 13, 2019 21:28:32 GMT 1
Or just make it a 2 pc part that replaces the old nylon bit
Mike
jay
2 stroke or not 2 stroke
Post by jay on Jan 17, 2019 0:28:07 GMT 1
Post by lolly on Jan 17, 2019 10:46:46 GMT 1
just ordered one ; I will let you know how I get on . I rebuilt my engine two years ago in the summer ; I wanted it done as quick as possible to get it back on the road ; so I didn't bother doing the "usual fix" . so now I have a constant small drip
Post by dusty350 on Jan 18, 2019 9:44:00 GMT 1
Great, it will be good to know how you get on with it. A cheap, easy fix, compared to an engine strip alternative ! Dusty
Post by lolly on Jan 18, 2019 10:34:48 GMT 1
Great, it will be good to know how you get on with it. A cheap, easy fix, compared to an engine strip alternative ! Dusty plus the good thing is you can install it with the selector shaft in situ ; I have just had awful problems installing a new clutch ; that casing has been on and off several times so I really did not want to too remove it again
Post by lolly on Jan 26, 2019 19:08:56 GMT 1
I have just fitted one ; I was shocked at the slack in the shaft ;the poor old seal didn't stand a chance . All of the slack has now gone and so far no seeping. BUT it is VERY close to the chain ; so hopefully it wont cause a problem
Post by 4l04ever on Jan 26, 2019 20:03:39 GMT 1
...and if you have a wobbly shaft, this adapter should also have a nice bush fitted to control the play and not wear the aluminium.
Sounds like a little machining job for someone to make some improved versions with double lip seals and a bush fitted.
