Post by stusco on Dec 31, 2018 21:09:32 GMT 1
Trying to remove the rusty needle bearings from my rg arm but they won’t budge I’m using a sliding hammer as hard as I dare the arm is flimsy and really light and I don’t want to damage it any tips?
Post by midlifecrisisrd on Dec 31, 2018 21:32:55 GMT 1
I tried a slide hammer with my rgv bearings without any joy
Had to use a puller in the end
Post by stusco on Dec 31, 2018 21:52:55 GMT 1
Cheers Steve
markw
Post by markw on Dec 31, 2018 21:53:41 GMT 1
When I replaced the bearings on my f2 swing arm I had the same problem I got round it by hack sawing gently through bearing casing two cuts did it, came out with no problem after
Post by stusco on Dec 31, 2018 22:20:53 GMT 1
It’s stepped there is a gap off about 10mm behind the bearings to get a puller in ,i might be able to grind them out
Post by midlifecrisisrd on Dec 31, 2018 23:27:25 GMT 1
It’s stepped there is a gap off about 10mm behind the bearings to get a puller in ,i might be able to grind them out You can borrow my internal bearing puller if you like Steve
Post by stusco on Dec 31, 2018 23:43:40 GMT 1
Cheers Steve I might take you up on that I’ll give it one more try
Post by Tobyjugs on Jan 1, 2019 11:25:44 GMT 1
One method of removal would be to remove the bearing internals so that you only have the outside bearing case still stuck in the arm. If you spot weld on the inside of the bearing case it will cause the case to deform and shrink making it easier to remove.
Post by Deleted on Jan 1, 2019 13:29:17 GMT 1
Heat and lots of it. Heat will break the rusted in seal. Let it cool down. If the slide hammer puller doesn't budge it then try a bit more heat. If it still doesn't move support the thing on some wooden blocks and drive it out from the far side. A normal hammer is no use you need a proper lump hammer.
Post by mak595 on Jan 1, 2019 13:39:56 GMT 1
One method of removal would be to remove the bearing internals so that you only have the outside bearing case still stuck in the arm. If you spot weld on the inside of the bearing case it will cause the case to deform and shrink making it easier to remove. i had to do this on one side, built up the inside with weld so got loads of heat into it and i had a good solid lump of weld to t**t the bearing out !!!
Post by madmick on Jan 2, 2019 12:05:47 GMT 1
We always remove the inner bits, then run a mig welder around the inside of the outer case. This will shrink the case for easy removal. Usually works on all bearings.
M.M.
Post by bare on Jan 3, 2019 20:19:15 GMT 1
Rusty? Pore thing spent time in the North Sea?
Post by stusco on Jan 3, 2019 21:07:35 GMT 1
Rusty? Pore thing spent time in the North Sea? Looks like it ,looks like it’s never saw grease and they are factory fitted originals
Post by mikee on Jan 4, 2019 11:07:44 GMT 1
You get them out yet ?
Mike
Post by stusco on Jan 4, 2019 18:32:02 GMT 1
Yeah blow torch and a 3lb hammer
