Post by marrcel on Dec 28, 2018 12:52:35 GMT 1
Hello smokers I just got a file for my 1983 31k rd350lc2 ypvs. I am just trying to understand the parameters. The stator and pick up are original. In the picture left of the green box there is a base setting of 10deg. How can i check if this is ok?
Post by marrcel on Dec 29, 2018 9:51:50 GMT 1
Let me refrace my question. When do you use this parameter? Only when you have an adjustable stator i presume. And rolling on the dyno this parameter is easier adjusted. Is 10deg then ok for the original stator?
Post by jessy03 on Dec 29, 2018 9:59:47 GMT 1
I’m not familiar with the ignitech but with the zeeltronic you can check your timing with degree wheel and strobe, programme a flat curve say 20degrees, find tdc rig a pointer up on your degree wheel and strobe it, hope that makes sense. Jess
Post by marrcel on Jan 2, 2019 8:33:28 GMT 1
Al the best for 2019! Is there anyone with an igni who is willing to take a look at this parameter? Thanks in advance. Cheers marcel
