Post by peter007 on Dec 22, 2018 15:07:10 GMT 1
hi guys has any of the experts on here got any advice on starting my newly rebuilt 350 4LO engine . premix in float bowls ? how long to let her run when started ? should i rev it once started or just let it tick over a while first ? so many questions lol just wanna get it right and not cause any damage . cheers in advance everyone ,Pete
Post by panzermatt on Dec 22, 2018 16:31:19 GMT 1
is the pump bled ?
Post by peter007 on Dec 22, 2018 16:41:23 GMT 1
It will be Matt yes motor is going back in the frame next week
Post by dusty350 on Dec 22, 2018 17:04:27 GMT 1
Hi Pete I started mine with an auxiliary tank with premix in it until I could fully bleed the pump. Leaving the petrol tank off meant I could check everything over once the engine was running. In fact, I probably run it up to temp 6 or 7 times before I fitted the petrol tank. If you need to adjust something it's easier with then tank off imo. Once running and ticking over, I look for any coolant leaks and generally just check everything is working as it should Dusty
Post by peter007 on Dec 22, 2018 17:07:53 GMT 1
Cheers dusty I’ll keep you posted on progress mate 👍🤞
Post by dusty350 on Dec 22, 2018 17:26:41 GMT 1
Good luck Pete, I bet it will be just fine Dusty
Post by Mr Kipling on Dec 22, 2018 17:34:14 GMT 1
As Dusty says start on some premix and let it idle for a while , check as she,s running..., I always look forward to the first start up after a rebuild.....Atb...
Post by peter007 on Dec 22, 2018 17:45:05 GMT 1
Exciting times ahead guys 🤞🤞😀
Post by mikee on Dec 22, 2018 19:39:20 GMT 1
Don’t run a tank of pre-mix and the pump , as dusty says , a wee auxiliary tank , a coolant overflow tank works well , if you over oil then it will run like a bag of shite and you’ll be off on a wild goose chase trying to sort it Do a couple of heat cycles then check for leaks I usually find th e head will need a bit more , and it’s a good idea to check the crankcase bolts and nuts (top and bottom ) The exhaust flanges will probably require a tweak as will the cooland hose clips I’d also say get it mot’d before you do this insued and taxed too , as,if it runs ,and it’s not raining you know you’ll want to give it just a wee run
Enjoy Mike
Post by JonW on Dec 23, 2018 11:29:39 GMT 1
yes, also bear in mind that premix is a leaner mix than straight fuel, so defo dont rant it on premix if jetted for normal fuel.
Post by peter007 on Dec 26, 2018 15:06:56 GMT 1
Moment of truth is here guys all back together going for the start up now !🤞
Post by madmick on Dec 26, 2018 15:48:14 GMT 1
WELL!!!!...... did it start???
M.M.
Post by peter007 on Dec 26, 2018 16:40:38 GMT 1
Did she ever ?!?! 4 kicks and straight off sweet as a nut ! Ear to the motor she’s silky smooth . Selects all gears and neutral is fine too . I’m a very happy boy today ! 😃😃😃trying to load a video of it running ? Anybody help me ? I’m using Tapatalk
Post by peter007 on Dec 26, 2018 16:47:51 GMT 1
Post by dusty350 on Dec 26, 2018 16:49:46 GMT 1
Congratulations Pete - great news. I've never used Tapatalk, but with Flikr you upload vids in exactly the same way as photos, just in case you have the option of Flikr. Dusty
Post by Mr Kipling on Dec 26, 2018 16:56:04 GMT 1
Yeah , well done with the start up congrats....
Post by dusty350 on Dec 26, 2018 16:58:48 GMT 1
Oh, and bike looks fantastic too Dusty
Post by peter007 on Dec 26, 2018 17:17:56 GMT 1
Post by stusco on Dec 26, 2018 17:29:04 GMT 1
Yep vid works nice bike sounds good it will be better in the band
Post by dusty350 on Dec 26, 2018 17:31:18 GMT 1
Sounds great Pete Vid works perfectly. Dusty
Post by peter007 on Dec 26, 2018 17:54:13 GMT 1
I’m now itching to ride it ! But not on these shit roads ☹️
Post by markstrange350 on Dec 26, 2018 19:19:08 GMT 1
Bike looks great . Must be killing you not to be able to ride it !
Post by peter007 on Dec 26, 2018 19:41:45 GMT 1
hey mark she might need a good wash after the next few days ! as long as the roads aren't white with grit and salt thinking shell start her apprenticeship fairly soon ?
Post by arrow on Dec 26, 2018 19:50:38 GMT 1
Sounds great. Well done.
Post by peter007 on Dec 26, 2018 20:06:06 GMT 1
Cheers Gary oil pump is spot on by the looks of it mate 👍
Post by arrow on Dec 26, 2018 20:08:01 GMT 1
Sorted.
Post by petenofear on Dec 26, 2018 20:13:11 GMT 1
Bike looks mint mate and sounds alsome
Get out and ride it you can always give it a clean when your back Well done mate
Post by madmick on Dec 26, 2018 20:17:27 GMT 1
Nice one Pete! That sound always makes my spine tingle 😍
M.M.
Post by peter007 on Dec 26, 2018 20:25:56 GMT 1
Like dusty says the motor really is an easy one to work on . Ok I’ve done my Suzuki gt250 before and that was different to the LC but the lc really is a nice engine to work on . Don’t be scared of it guys if I can do it you all can just use the right tools ok 👍
Post by Tobyjugs on Dec 26, 2018 21:55:15 GMT 1
Great looking bike and sounds nice as well. Are you using standard baffles or something slightly different?
