Rebore
Dec 20, 2018 13:45:41 GMT 1
Post by supermoto57 on Dec 20, 2018 13:45:41 GMT 1
Hi folks looking to get my lc re bored ,was thinking on using Grampian ,are they ok or have you any other recommendations,thanks ewan
Rebore
Dec 20, 2018 14:10:05 GMT 1
via mobile
justyr likes this
Post by midlifecrisisrd on Dec 20, 2018 14:10:05 GMT 1
I've used them many times now for both crank rebuilds and rebored
Never had an issue and a really fast service
Always Jap made Mitaka pistons
Unlike another well known place that sent ones from Taiwan ๐
Rebore
Dec 20, 2018 14:15:54 GMT 1
Post by supermoto57 on Dec 20, 2018 14:15:54 GMT 1
Thanks Steve thatโs what I thought ,they seem to know there stuff,do they check ring gaps or do I need to do that once I get them back,or simply fit and go.Ewan
Rebore
Dec 20, 2018 14:18:21 GMT 1
via mobile
Post by badger1 on Dec 20, 2018 14:18:21 GMT 1
Sent mine on the Monday to Grampianโs came back on the Wednesday.
Rebore
Dec 20, 2018 15:57:32 GMT 1
Post by supermoto57 on Dec 20, 2018 15:57:32 GMT 1
Thatโs what I call good service,did you just fit yours and go ,or is there anything else to do before fitting ,thanks ewan
Rebore
Dec 20, 2018 16:02:14 GMT 1
via mobile
Post by midlifecrisisrd on Dec 20, 2018 16:02:14 GMT 1
Ring gaps should be ok but I always check them
You need to wash the barrels out in till you can wipe them with a cloth soaked in wd40 and there is no residue
I usually use a carb or brake cleaning aerosol
Rebore
Dec 20, 2018 16:29:08 GMT 1
Post by supermoto57 on Dec 20, 2018 16:29:08 GMT 1
What is the correct gap for them Steve ,Ewan
Rebore
Dec 20, 2018 16:39:16 GMT 1
via mobile
Post by midlifecrisisrd on Dec 20, 2018 16:39:16 GMT 1
Can't remember off the top of my head
There is a figure in the manual but ring gaps are usually bigger than what they state
Rebore
Dec 20, 2018 16:46:32 GMT 1
Post by supermoto57 on Dec 20, 2018 16:46:32 GMT 1
Ok thanks ,Iโm sure Grampian will check this anyway ,I better get the spannerโs out and start stripping as Iโve only got 75 psi on both cyinders๐ก.ewan
Rebore
Dec 20, 2018 16:55:10 GMT 1
via mobile
Post by midlifecrisisrd on Dec 20, 2018 16:55:10 GMT 1
God that's low
Did you have the throttle wide open?
Rebore
Dec 20, 2018 17:03:37 GMT 1
Post by supermoto57 on Dec 20, 2018 17:03:37 GMT 1
Yes kicking like crazy best I can get is 75 tried it on my 350 and irs the same so guess itโs got to come to bits soon ๐
Rebore
Dec 20, 2018 17:08:04 GMT 1
Post by 4l04ever on Dec 20, 2018 17:08:04 GMT 1
I would recommend Grampian too. Super fast service and very knowledgeable. Have all oversize pistons in stock. They can supply small end bearings too.
Rebore
Dec 20, 2018 17:11:00 GMT 1
Post by supermoto57 on Dec 20, 2018 17:11:00 GMT 1
Yes they quoted ยฃ80 per cylinder that was for everything which I thought was reasonable. Ewan
Rebore
Dec 20, 2018 17:40:23 GMT 1
Post by jackjabba on Dec 20, 2018 17:40:23 GMT 1
It depends on where your based. I use Mick Abbey as he is 10 minutes from me so no postage costs. Even if he wasn't that close I would still use him.
Rebore
Dec 20, 2018 18:03:20 GMT 1
Post by supermoto57 on Dec 20, 2018 18:03:20 GMT 1
Well Iโm up in Aberdeenshire Scotland ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ I am going to go with Grampian I think ,postage wonโt be cheap but I will just have to put up with it.๐.Ewan
Rebore
Dec 20, 2018 18:10:46 GMT 1
via mobile
Post by midlifecrisisrd on Dec 20, 2018 18:10:46 GMT 1
Well Iโm up in Aberdeenshire Scotland ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ I am going to go with Grampian I think ,postage wonโt be cheap but I will just have to put up with it.๐.Ewan Once you have them boxed up weigh and measure it then get onto interparcel.com and select UPS economy. Only about a tenner Steve
Rebore
Dec 20, 2018 18:15:35 GMT 1
Post by supermoto57 on Dec 20, 2018 18:15:35 GMT 1
Cool will try that,thanks Steve ๐
chrisk
Rebore
Dec 21, 2018 18:05:50 GMT 1
via mobile
Post by chrisk on Dec 21, 2018 18:05:50 GMT 1
Rayspeed on the A64 between Malton and Scarborough.
You need to supply pistons. Also you need to state what clearance required.
Ben is the guy who does the boring.
I've pushed the limit on tight clearances with him, ypvs at less than a thou n a half. Which was also run on motul 800 immediately. Produces decent power with very very little mods, and gets taken to 10k nearly every time I nip out.
400 a bit tight, first time round, but happy at just over a thou...and likewise gets reved. Also on motul 800, very very little mods, and surprisingly quick.
Basically a good accurate bore and tight clearances with good oil (pumps both plus 10 by arrow) have for me at least, helped towards good power and reliability.
Ben is very patient, and a very interesting guy if your into two strokes. He can actually design cylinders, and 3d prints them to test flow etc.
Oh.. I take all sharp edges of pistons, even the edge of the machine chambers.
Rebore
Dec 21, 2018 18:21:06 GMT 1
Post by abar121 on Dec 21, 2018 18:21:06 GMT 1
Grampian, Mick or PJ Engineer if you think a resleeve might be needed.
Rebore
Jan 11, 2019 12:13:01 GMT 1
Post by paulsx on Jan 11, 2019 12:13:01 GMT 1
I've used Grampian, PJ and Rob at Spa motorcycles. The Grampian stuff has always been very good, well priced and very fast turn around. Found PJ too expensive last time they quoted for a rebore but work has always been good. Rob at SPA bored my aircooled barrels and really knows his stuff, even thou used gen yamaha pistons he carfeully measured and bored each one to suit and even phone me in the evening to discuss it. Top bloke
antos
Rebore
Jan 14, 2019 18:41:20 GMT 1
via mobile
Post by antos on Jan 14, 2019 18:41:20 GMT 1
I took mine down to Grampian from Durham , took the chance to explore the area so took our lass too , made a weekend of it. Had rebore and did the crank for me as well top lads ! Iโve put around 2k on it since last year with no problems at all ๐
Rebore
Mar 15, 2019 10:40:13 GMT 1
Post by mellow on Mar 15, 2019 10:40:13 GMT 1
I'm going to be posting my crank & barrels off to Grampians to be checked once i have stripped them out. Do i need to do any prepping first? obviously power valves will be removed. Do i send the pistons with the barrels to be checked or do they just measure the barrel?
Rebore
Mar 15, 2019 11:03:01 GMT 1
via mobile
mellow likes this
Post by midlifecrisisrd on Mar 15, 2019 11:03:01 GMT 1
If you are wanting them checked then yes send pistons. Remember to mark them left and right
Chances are although they look ok they will need a rebore
It's an engineering thing. If it ain't perfect then it's wrong ๐
Might get away with new pistons as the alloy should wear faster. As long as the bore isn't oval
Rebore
Mar 15, 2019 11:39:13 GMT 1
Post by Deleted on Mar 15, 2019 11:39:13 GMT 1
You need to wash the barrels out in till you can wipe them with a cloth soaked in wd40 and there is no residue.
In my experience ,if you have cleaned the barrels properly. They will start to flash rust in 5 minutes.
Rebore
Mar 15, 2019 12:53:45 GMT 1
via mobile
Post by Tobyjugs on Mar 15, 2019 12:53:45 GMT 1
You need to wash the barrels out in till you can wipe them with a cloth soaked in wd40 and there is no residue. In my experience ,if you have cleaned the barrels properly. They will start to flash rust in 5 minutes. Believe it or not soapy water works well, if it's just come from the honing bank.
Rebore
Mar 15, 2019 16:16:44 GMT 1
Post by mellow on Mar 15, 2019 16:16:44 GMT 1
Thanks guys, but i mean before i send them off not when they come back
Rebore
Mar 17, 2019 10:31:38 GMT 1
Post by mellow on Mar 17, 2019 10:31:38 GMT 1
Do i need to remove the studs from the barrel before sending to Grampians?
Rebore
Mar 17, 2019 11:03:37 GMT 1
Post by jon on Mar 17, 2019 11:03:37 GMT 1
Hi Mick,
When Iโve taken barrels to Bob Farnham in the past he has asked if I have cleaned the gasket face up first. Itโs a pig to do if an OEM gasket has been used as it sticks like glue. If not he would have charged extra.
You need this perfectly flat to bore parallel.
Studs can stay in.
Rebore
Mar 17, 2019 11:10:07 GMT 1
via mobile
Post by mellow on Mar 17, 2019 11:10:07 GMT 1
Cheers Jon. Have cleaned gasket surfaces already. Off to split the cases now๐๐
