antos
Post by antos on Dec 17, 2018 23:14:41 GMT 1
Guys when ignition is turned on this pulley turns to the right first yes? Thanks
Post by jessy03 on Dec 17, 2018 23:15:24 GMT 1
Yes that’s correct
antos
Post by antos on Dec 17, 2018 23:23:18 GMT 1
Thanks mate👍
Post by panzermatt on Dec 18, 2018 19:10:34 GMT 1
i wouldnt trust that hole you line up, i checked mine as the exhauste were off, and at least 1mm of valve was still in port, so i set it until it was lovely and flush. then checked the line up thingy, and that was off about 1.5 mm
Post by jon on Dec 18, 2018 20:32:13 GMT 1
i wouldnt trust that hole you line up, i checked mine as the exhauste were off, and at least 1mm of valve was still in port, so i set it until it was lovely and flush. then checked the line up thingy, and that was off about 1.5 mm Matt, purely out of interest have you ever had the pulley housing off? I’ve seen one once with elongated holes tightened up and was out as you describe. Of course that’s not the only reason, but just asking out of interest. Jon
Post by panzermatt on Dec 18, 2018 21:28:04 GMT 1
i did very recently, it looked ok. never thought of that to be honest.
Post by bazzer5115 on Dec 19, 2018 9:03:51 GMT 1
Always check mine by removing exhausts,and looking up exhaust ports. It’s the the most accurate way.👍
Post by Tobyjugs on Dec 20, 2018 10:32:35 GMT 1
Happy birthday Antos
Post by roach3 on Dec 24, 2018 0:30:35 GMT 1
so mine has a zeel fitted and I believe you set the valves up differently is this correct? if so how do I set them up?
cheerz guys
Post by JonW on Dec 24, 2018 0:57:29 GMT 1
you set the values for the start, just adjust the numbers and you can feel it move closer or away from where you want it. easy to do.
Post by stusco on Dec 24, 2018 8:39:20 GMT 1
so mine has a zeel fitted and I believe you set the valves up differently is this correct? if so how do I set them up? cheerz guys On the clean cycle turn ign on when it moves and stops turn ign off this is fully open peg it with 4mm drill adjust your cables
Post by jessy03 on Dec 24, 2018 11:06:38 GMT 1
so mine has a zeel fitted and I believe you set the valves up differently is this correct? if so how do I set them up? cheerz guys Set it up as normal then plug in your programmer/laptop and go to test open/close then adjust from there, exhausts off and fingers up the exhaust port. From memory values are 210 open 540 closed or other way round can’t remember, all slightly different though. Jess
Post by roach3 on Dec 25, 2018 2:00:54 GMT 1
thnx guys only problem is I don't have the hand programmer
Post by jessy03 on Dec 25, 2018 10:39:52 GMT 1
thnx guys only problem is I don't have the hand programmer Where in world are you? Sure somebody could lend you one, or even pop round and do it
