Post by jazzyjembreaze on Dec 16, 2018 17:30:06 GMT 1
I’m pretty sure the fork in new form would have a bung then once removed a circlip or retaining snap ring would secure the spring top for removal / no such luck on mine , it just looks nasty , am I right in thinking the bung has snapped off at some point and it’s metal retaing collar is still inside ,as I can’t see a circlip there is a gap if I put my finger in between the spring top & this collar , I don’t just want to pry at it before asking , anyway both look like this & are corroded badly flic.kr/p/Rt7P3jflic.kr/p/2dwtZBGRegards mic
Post by mellow on Dec 17, 2018 20:06:20 GMT 1
You have to push the metal cap down to reveal the clip. Can take some persuasion if not moved for a while, or worse rusted in I worked mine out before by tapping gradually with a 14mm socket on an extension bar to get it to move
Post by jazzyjembreaze on Dec 17, 2018 21:30:32 GMT 1
Ahh right , I’ve left them soaking for a day , so this mess is actually the cap , wich needs pushed down revealing the clip / that’s the gap I can feel with my finger , thanks m8 will get straight on it tomorrow 👍👍
Post by mellow on Dec 17, 2018 21:32:52 GMT 1
Yeah softly softly though mate🙄the caps are no longer available so don't punch through it😐👍
Post by jazzyjembreaze on Dec 18, 2018 0:06:48 GMT 1
Cool , try my best , very corroded in there so fingers crossed x
Post by jazzyjembreaze on Dec 18, 2018 12:49:17 GMT 1
Not moving as yet Am I supposed to tap the inner lip of the cap or the centre through the hole ? The workshop manual states pushing down with a screwdriver if that’s the case the centre will push leaving a gap between this inner cap revealing the circlip & spring pressure will force the inner cap up ? Is this correct
Post by mellow on Dec 18, 2018 17:23:42 GMT 1
Yes. Put a socket on a bar so it sit on the flat bottom bit of cap. Push down, then try to lever clip out. extra pair of hands normally useful
Post by jazzyjembreaze on Dec 18, 2018 20:04:24 GMT 1
Thanks m8 Let it soak again tonight / sort it in morn 👍
Post by jazzyjembreaze on Dec 20, 2018 14:12:50 GMT 1
Thanks for your assistance mellow much app 👍
Post by mellow on Dec 20, 2018 18:09:38 GMT 1
No problem mate. been there myself. Had to cut a stanchion top off before Now get the cap rust treated and preserved. The clips and o rings are available new
