Post by mollers on Dec 12, 2018 10:15:59 GMT 1
Morning to all,
Stupid question coming up, my F2 restro has slightly bent clip-ons, one is worse than the other.
Question - Should they be bent ??!!!! and if so is it possible to straighten them as I understand they are now unavailable from Mr Yam.
Cheers all
Mollers.
Post by mellow on Dec 12, 2018 10:30:43 GMT 1
Post by JonW on Dec 12, 2018 12:06:13 GMT 1
They should be straight. You would be surprised what a hit with a rubber mallet can do or a bend with a bit of scaf pipe...
Post by mollers on Dec 12, 2018 12:29:59 GMT 1
Thanks for the replies chaps, will give it a go myself, if not try motoliners.
Post by kostas on Dec 12, 2018 17:45:19 GMT 1
I straightened mine a few years back. Just inspect closely for cracks after you straighten those
Post by jon on Dec 12, 2018 19:00:17 GMT 1
I simply ground the old ones off, and replaced with new tube.
The clamp is a casting with a stub on it that Yamaha simply slid a 7/8” tube over and spot welded it. The R models also have a bit of brasing on the end.
Post by Tobyjugs on Dec 12, 2018 19:04:24 GMT 1
Yes I also did the same a Jon
Post by midlifecrisisrd on Dec 12, 2018 19:05:47 GMT 1
They are made of cheese
Fit them to the bike or clamp in a vice and put a 2ft bar over and tweak
They are so shortly made I had 2 new ones that when put in a jig they were not the same
Post by bare on Dec 12, 2018 22:37:35 GMT 1
I used heat .. Cautiously. It at least doesn't produce hidden fractures.
Post by JonW on Dec 13, 2018 0:13:36 GMT 1
Ive a bunch of F1 bars I was going to weld new bars onto the stubs and bought some NOS ones to use for making the jig. Less easy to do than the F2s of course and ive not got round to it yet, sigh. Still, no harm sitting on the nos F1s, not like theyre getting cheaper lol
Post by zedixe13 on Dec 13, 2018 9:01:29 GMT 1
I'm using 1986 FZ600 clip on , they are 36mm but they fit perfectly with a simple 0,5 mm sleeve , cheap and plenty .
