Post by aid22 on Nov 12, 2018 15:27:58 GMT 1
Hi to all,
What's the difference between an LC g/box and a PV one, and how can you tell?
Aid.
Post by 4l04ever on Nov 12, 2018 16:19:23 GMT 1
The YPVS gearbox hosing is slightly wider, so the output shaft and selector drum are longer. I think a couple of the gears are the same and the bearings. Compare the part numbers and you will see :-) They are certainly not interchangeable in full.
Post by aid22 on Nov 12, 2018 17:44:58 GMT 1
Thanks for that . I will check them tomorrow and share the outcome.
Post by dusty350 on Nov 12, 2018 20:01:43 GMT 1
Post by aid22 on Nov 13, 2018 14:05:05 GMT 1
Thanks for doing that Dusty. It's clear to see and I remember the difference, although it has been a long time since I messed about LC's so I will need some guidance . Aid.
Post by 4l04ever on Nov 13, 2018 17:36:26 GMT 1
Post by Tobyjugs on Nov 13, 2018 18:37:49 GMT 1
I'm about to build and engine with a mixture of Banshee and YPVS gearbox parts (that could be a head scratcher}. Thanks for the tip mutts.
