Post by nick1969 on Nov 9, 2018 0:37:44 GMT 1
Does anyone have experience of the Rev counter appearingvover sensitive? It seems quite accurate but it takes a while to settle when you rev the bike from tickover? It’s a 31k
Thanks chaps
Post by kostas on Nov 9, 2018 16:18:58 GMT 1
Rev counter is sensitive to erratic voltage output from the stator or dead battery. I would start with checking those
Post by earthman on Nov 9, 2018 17:24:09 GMT 1
I'm not familiar with the 31k model period, I assumed that the Rev counter were cable driven like the 4LO is. That's what I've learned today.
Post by rich on Nov 9, 2018 17:55:03 GMT 1
31k (as in LC2) has a cable driven tacho so probably a cable issue or the tacho itself as they are prone to sticking
Post by kostas on Nov 9, 2018 20:43:23 GMT 1
31k (as in F1) was what I had in mind...
Post by earthman on Nov 9, 2018 21:43:21 GMT 1
Ah,....the plot thickens with every model/version hey.
Post by Yogi on Nov 10, 2018 9:07:28 GMT 1
Ah,....the plot thickens with every model/version hey. Lc2s were cable,n1/f1,n2/f2/r were not
Post by nick1969 on Nov 11, 2018 19:22:38 GMT 1
Yes its cable driven, so i guess it can only be at the drive end or the tacho it's self. I am thinking its probably the taco, but I've never stripped the clocks before and don't really want to do it unless it is absolutely necessary.
Post by stusco on Nov 11, 2018 19:47:12 GMT 1
Easy on a lc2 just a couple of screws unlike a 4l0/4l1
Post by yamman1066 on Nov 11, 2018 20:05:51 GMT 1
new cable and some oil where the cable fit to the tacho , may do the job
Post by LC_BOTT on Nov 11, 2018 20:25:34 GMT 1
Sounds a bit like the clock spring could be damaged or broken. I am assuming they still have the springs, long time since I've looked at some LC2 clocks.
