Post by philmill on Nov 6, 2018 19:16:31 GMT 1
So having made the mistake of buying a pair of Kawasaki 6 pot calipers, can you guys confirm all Suzuki 6 pot fit the RGV forks??
Thanks, Phil
Post by bazzer5115 on Nov 6, 2018 19:30:12 GMT 1
Got 6 pots on one of my hybrids,look good,stop good. No problem at all. Biggest problem with tokico 6 pots is pistons sticking due to corrosion,but unlikely you going to be riding through winter on salted roads👍
Post by bazzer5115 on Nov 6, 2018 19:31:22 GMT 1
If I remember correctly,they all 90mm centres👍
Post by JonW on Nov 7, 2018 0:46:45 GMT 1
I have em on my hyrbid as well, from a Busa.
Post by marrcel on Nov 7, 2018 12:01:23 GMT 1
Swopped the 6pots for 4pots on my track gixxer. The smaller the pistons the more they stick on the seal. Happier with the 4pots from srad600
Post by headcoats on Nov 7, 2018 12:54:21 GMT 1
Always thought a bit OTT for the super light weight Elsies !
Post by philmill on Nov 7, 2018 14:31:27 GMT 1
Yes 6 pots are OTT but they do look the part... I read a lot about the RGV 4 pot items feeling a bit "wooden" I'm still undecided but soon need to do something.
Phil
Post by morgy on Nov 7, 2018 15:05:37 GMT 1
Hi Phil I was told today The Kawasaki and Suzuki ones are the same if they have the 27mm & 24mm pots... Don't do what i did and bin the pistons as they were a bit crappy full rebuild kit had just cost me £180!! IMG_0631 by mark.morgan07, on Flickr
Post by bare on Nov 8, 2018 4:58:38 GMT 1
Care ... It's not Brakes that stop you.. rather it's the tires gripping the road. Recently had some t**t with earbuds in, run out between parked cars. Riding My 600rr (near new Pirelli Diablo Corsas) ~ 60kph Did a stoppy and even laid long black streaks on the road. Damn near gave me religion. Didn't drop the bike though. t**t carried on Jogging.. not even aware of how close she came to dying.. or worse. Good brakes certainly but Really Good tires.. with previous Bridgestones it would have been ugly for all concerned.
Post by JonW on Nov 8, 2018 9:27:52 GMT 1
I played with a few masters (now using an R1 Brembo radial) and also different lines. I use the OEM 'busa lowers and the top line is a braided one from a Triumph I think. Has lots of feel and not too harsh. 1 finger braking tho for sure. Grab a handful without thinking and you'll lock the front. Is it too much... sure, but as bare says there is more to braking, that also includes tyres and the rider.
Post by philmill on Nov 8, 2018 16:30:16 GMT 1
Hi Phil I was told today The Kawasaki and Suzuki ones are the same if they have the 27mm & 24mm pots... Don't do what i did and bin the pistons as they were a bit crappy full rebuild kit had just cost me £180!! IMG_0631 by mark.morgan07, on Flickr I bought some Kawasaki ones and they don't fit, the mounting spacing is wrong... Phil
Post by morgy on Nov 8, 2018 18:51:03 GMT 1
Hi Phil I was told today The Kawasaki and Suzuki ones are the same if they have the 27mm & 24mm pots... Don't do what i did and bin the pistons as they were a bit crappy full rebuild kit had just cost me £180!! IMG_0631 by mark.morgan07, on Flickr I bought some Kawasaki ones and they don't fit, the mounting spacing is wrong... Phil As said above if they have 90mm hole spacing and the pistons are 27mm and 24mm then there the same, The guy i bought my repair kit off told me this. if there the version with all the pistons the same he said they were different.
