Post by hudtm60 on Nov 1, 2018 3:38:50 GMT 1
So....let me guess you're not supposed mask it and then leave it for four months when life intervenes and 2) you're supposed to pull off the masking tape while the paint is still.....wet? as for the scratch- that'll polish out....heh.
Post by hudtm60 on Nov 1, 2018 4:29:33 GMT 1
was going for this look from Dusty's project....(or one of them)
Post by kostas on Nov 1, 2018 18:50:29 GMT 1
Practice makes perfect,
You have some catching up to do to match Dastys result!!
Post by shaunthe2nd on Nov 1, 2018 19:12:55 GMT 1
Use a low tack masking tape and take it off once paint is touch dry, and before you bake it in the oven.
Post by hudtm60 on Nov 1, 2018 22:45:14 GMT 1
wait- bake it in the oven?....how long and at what temp please Mr Craddock?
Post by donkeychomp on Nov 1, 2018 23:08:21 GMT 1
I used a permanent silver marker. I plonk mine on a oil fired radiator for about an hour.
Post by shaunthe2nd on Nov 1, 2018 23:35:10 GMT 1
140 degrees for 45 mins
Post by hudtm60 on Nov 2, 2018 2:38:16 GMT 1
thank you sir.... and I hope they don't turn out like Fanny's.... moving on I think I'm going to strip them and try again.....they don't look too bad from a distance tho...but I've learnt not to paint the top of the cylinders as there it's not a clean line...it looks raggedy looking down on them....incidentally u can see the difference in the port here....someone's been messing with the left one.
