Post by philmill on Oct 31, 2018 20:20:25 GMT 1
Hi guys, I'm interested in buying the pipes currently for sale on the Forum, but as I have a 31k I'm hoping somebody can tell me how much difference there is in the mounting, if it means adding bits or extra parts then I'll leave them, but if its only a case of elongating the existing hole then that's fine.
Thanks, Phil
Post by midlifecrisisrd on Oct 31, 2018 21:30:16 GMT 1
You would need to offer them up to the bike to be sure
There is about an inch difference
If you look at the old microns the pipes were the same but the bracket was longer so they looked droopy on a ypvs
The hole is higher and slightly further back
Those brackets look really easy to bolt on a small adaptor plate but they will sit lower than the footplate hanger
Post by midlifecrisisrd on Oct 31, 2018 21:32:25 GMT 1
Just looked at the picture of them on an lc and they are real close to the frame rail and side stand bracket
Post by philmill on Oct 31, 2018 22:35:12 GMT 1
Thanks Steve, its too much of a risk, I have been meticulous with this build, can't run it with something so big, shame as I like the look of the pipes.
Phil
Post by bare on Nov 1, 2018 3:25:06 GMT 1
I found that My old 'codnor' LC Microns (both pairs) Didn't fit worth shite on My LC's. Ended up Cutting off the Rear brackets entirely, fabbing New ones and rewelding once I had clamped the pipes into Perfect Alignment. Header tubes now actually slide and the chambers are well fitted under the engine ..nicely spaced from everything they could rattle against. Ended up that the new brackets were notably different in shape and location on the pipes from the Factory efforts Took an entire day's work though... so not a trivial bodge.
Post by mikee on Nov 1, 2018 13:49:23 GMT 1
you used to be able to fit the old condor microns in a GP style bend , with a bit of heat ,the rh side pipe slightly to the right , then fit it to the left hand cylinder running out to the righthand side , a tweek to the mount was required then fit the lefthand side pipe to the right hand side
mike
