Post by panzermatt on Oct 30, 2018 21:33:06 GMT 1
just a thought lads, when tightening the flywheel and the main crank nut on the clutch side, coul you not do both at the same time? they would work against each other no? or do i deserve a hiding for this?
Post by Yogi on Oct 30, 2018 22:21:59 GMT 1
There'd be a good chance of twisting the crank
I'd rather lock each side individually myself
Matt
Post by kostas on Oct 30, 2018 22:26:50 GMT 1
You canโt be sure that the crank wonโt go out of alignment by doing this, And there is clearly no reason for doing this. You can make the tools yourself to hold the flywheel and the primary drive gear.
So itโs a no for me
Post by mikee on Oct 31, 2018 10:42:31 GMT 1
stick a 2p in the primary gears when tightening the primary drive nuts
just make sure its a copper coin
as above , youll twist the crank tightening from the other side
mike
Post by midlifecrisisrd on Oct 31, 2018 16:11:56 GMT 1
stick a 2p in the primary gears when tightening the primary drive nuts just make sure its a copper coin as above , youll twist the crank tightening from the other side mike Newsflash! Coppers are no longer made of copper, haven't been for years They are plated steel ๐ Steve
Post by panzermatt on Oct 31, 2018 18:52:07 GMT 1
so it WAS a stupid idea!
Post by earthman on Oct 31, 2018 19:00:26 GMT 1
Don't be so hard on yourself, we can all have them from time to time. It's great to thrash out ideas etc, this forum is a fountain of knowledge so we can all learn something at some point I'm sure.
Post by mikee on Oct 31, 2018 22:57:29 GMT 1
stick a 2p in the primary gears when tightening the primary drive nuts just make sure its a copper coin as above , youll twist the crank tightening from the other side mike Newsflash! Coppers are no longer made of copper, haven't been for years They are plated steel ๐ Steve Hence my statement I do have a pile of copper 2pโs , ยฃ1 each if you want one , lol Mike
Post by bare on Nov 1, 2018 3:16:16 GMT 1
Coppers are no longer made of copper, haven't been for years They are plated steel ๐ Steve Jeez... they've even adulterated your coins. Can't be much left to Eff up... can there?
Post by darboots on Nov 1, 2018 9:31:06 GMT 1
Coppers are no longer made of copper, haven't been for years They are plated steel ๐ Steve Jeez... they've even adulterated your coins. Can't be much left to Eff up... can there? Brexit negotiations are taking care of the rest...
