Post by chequeredflagracing on Oct 17, 2018 18:12:02 GMT 1
Has anyone had copies of these made? Alloy Nylon 3D print
Post by LC_BOTT on Oct 17, 2018 18:50:07 GMT 1
There were some made a few years ago, I bought a set, as they are usually missing it seems. Dropped one on the floor and it shattered immediately, so couldn't say what they were made from (no not glass). treat with kid gloves if you find them, 3D print must be an easy option for these.
Post by bare on Oct 18, 2018 18:08:20 GMT 1
3d prints could be either good or shite (I have a 3d gizmo) Typically the prints are of rough texture /finish. Although in ABS they can be smoothed out with acetone..the stuff melts the surface into a smooth finish.. mostly. A commercial place like Shapeways can do a much higher print quality than any home printer.
Post by muttsnuts on Oct 18, 2018 19:09:47 GMT 1
fzr1000 forks use the same ones, I bought a set of forks just for the anti-dive units once, still got the forks here, reminds me I need to get rid of them, in lovely condition as well !
Post by 500anorak on Oct 18, 2018 21:36:12 GMT 1
fzr1000 forks use the same ones, I bought a set of forks just for the anti-dive units once, still got the forks here, reminds me I need to get rid of them, in lovely condition as well ! Only the 47X pre-production bikes used the FJ/FZ anti dive units, here is a nos set i used on my 47X pre-production bike. Production bikes anti dives were unique to the rd/rz/rzv500 The caps which were made years a go were copies of the smaller FJ/FZ anti dive cap.
Post by muttsnuts on Oct 19, 2018 9:28:15 GMT 1
it was only the caps that where different though iirc and most people wouldn't even notice of know that TBH I would have thought
Post by 500anorak on Oct 19, 2018 15:46:52 GMT 1
The tops are the same but nothing else
Post by pilotmarky on Oct 23, 2018 21:02:11 GMT 1
I also need some of these for mine. If anyone has a line on some, let me know!
Post by chequeredflagracing on Mar 15, 2019 9:13:50 GMT 1
Post by chequeredflagracing on Mar 15, 2019 9:17:14 GMT 1
Had a 3D test print done. Looks like Yamaha may have moulded the plastic around the bolt head to keep it captive. 3D print one will likely have to have a cap on the bottom. Interference fit for bolt and use adhesive to make sure it stays put and for the the press in cap. More when I have it to hand
Post by JonW on Mar 15, 2019 11:05:13 GMT 1
Interested to see how this works out.
Post by pilotmarky on Mar 15, 2019 12:40:18 GMT 1
Oh man, the eBay item was gone fast. I would also be interested in the 3D printed ones!
Cheers,
Post by chequeredflagracing on Mar 16, 2019 9:10:00 GMT 1
Getting there. Test item. But ID needs to be larger to go over clear plastic sleeve. He's on with another as I type. Interference fit for bolt and use adhesive to make sure it stays put and for the the press in cap.
Post by chequeredflagracing on Mar 16, 2019 9:12:54 GMT 1
Ignore the shape. It's a test item.
Post by chequeredflagracing on Mar 16, 2019 11:12:41 GMT 1
Post by chequeredflagracing on Mar 19, 2019 21:30:51 GMT 1
First test piece
Post by JonW on Mar 19, 2019 23:54:44 GMT 1
looks good.
