Post by 17again on Oct 1, 2018 19:26:14 GMT 1
just got my bars for my hybrid today. do you think they look ok on a full faring bike? used to seeing clipons also which front master cylinders do uses that look ab but trick with the separate tank for the brake fluid, comes with a little bar to hold it. i think the normal one might hit the fairing on full lock. thanks max
Post by midlifecrisisrd on Oct 1, 2018 19:58:38 GMT 1
I've just been considering this an undecided
What bars are you using? Are they renthal 758 ultra low?
May just need flatter bars
Post by 17again on Oct 1, 2018 20:08:36 GMT 1
No there 754 low road bars.
I wanted them as there not so straight..
Post by aid22 on Oct 1, 2018 20:12:35 GMT 1
Mmm? Not doing it for me.
Post by stusco on Oct 1, 2018 20:22:10 GMT 1
Mmm? Not doing it for me. :-) Me neither Iām afraid maybe flat bars
Post by aid22 on Oct 1, 2018 20:29:10 GMT 1
Flatter may work but fairing = clip one and naked = bars. :-)
Post by midlifecrisisrd on Oct 1, 2018 20:34:23 GMT 1
No there 754 low road bars. I wanted them as there not so straight.. 758 are same shape but about half the height Steve
Post by midlifecrisisrd on Oct 1, 2018 20:36:28 GMT 1
758's
Post by 17again on Oct 1, 2018 20:40:50 GMT 1
I looked on the website and the road bars bend round more.
But are also higher.
Do you think I could change the risers or machine them down..?
There spondon440 Yokes
Post by midlifecrisisrd on Oct 1, 2018 21:02:12 GMT 1
Not by much I don't think
Maybe 5mm off the riser which ain't much
Post by veg on Oct 1, 2018 23:09:36 GMT 1
Do they work for you? Are you comfortable? If itās yes and yes who cares what anyone thinks?
Post by doohanno1 on Oct 1, 2018 23:21:15 GMT 1
The " pinions" part cofused me..š¤
Post by JonW on Oct 1, 2018 23:44:55 GMT 1
The " pinions" part cofused me..š¤ me too, then I worked it out and... I'm also not feeling the bars. Ok in pic 1, but not in the rest. sorry.
Post by doohanno1 on Oct 1, 2018 23:52:16 GMT 1
I think i'd whip the fairing off...
Post by earthman on Oct 2, 2018 7:33:20 GMT 1
Personally I'd be more concerned about the riding position bars provide rather than looks,...clip on's are neat etc but if I can hardly ride the bike, there's no point me fitting them.
I'd like to fit straighter/higher bars to my 4LO at some point but the hassle of finding longer control cables and switch gear wires is putting me off.
Post by LC_BOTT on Oct 2, 2018 7:52:39 GMT 1
Flatter may work but fairing = clip one and naked = bars. :-) Agree with this, or bin the standard fairing, and go with a bar mounted version, no probs with M/cyl etc then.
Post by dusty350 on Oct 2, 2018 8:05:19 GMT 1
Hi For comfort, they look good. For looks - don't think they suit the bike in my opinion, but as said, if you like it that's all that matters. I'm guessing you are not sure, hence asking for opinions, but I think lower bars would look better. I think the clip ons that mount above the yoke as standard on these have the right "look", but you may struggle to do that now. Unfortunately, as with a lot of components, having the look that you want doesn't always mean you get the comfort . I really like straight bars on unfaired bikes, but they are not that comfortable for me and cause issues with cable routing. I fitted low rise bars on mine in the end as it saved on loads of hassle, and just got used to the look of them. Regards front brake - I used a Gsxr750 K3 master with a billet ally pot which is the smallest I could find; 20171228_120433 by David Miller, on Flickr Couldn't find anywhere in this country that did the pot. It came from Australia !! Nice looking hybrid too - great job Dusty
Post by 17again on Oct 2, 2018 8:22:51 GMT 1
so i have twisted them back it bit and they seem to look better? i was thinking would it help if it changed the risers to lower ones? or it just looks wrong?
Post by 17again on Oct 2, 2018 8:27:57 GMT 1
Hi For comfort, they look good. For looks - don't think they suit the bike in my opinion, but as said, if you like it that's all that matters. I'm guessing you are not sure, hence asking for opinions, but I think lower bars would look better. I think the clip ons that mount above the yoke as standard on these have the right "look", but you may struggle to do that now. Unfortunately, as with a lot of components, having the look that you want doesn't always mean you get the comfort . I really like straight bars on unfaired bikes, but they are not that comfortable for me and cause issues with cable routing. I fitted low rise bars on mine in the end as it saved on loads of hassle, and just got used to the look of them. Regards front brake - I used a Gsxr750 K3 master with a billet ally pot which is the smallest I could find; 20171228_120433 by David Miller, on Flickr Couldn't find anywhere in this country that did the pot. It came from Australia !! Nice looking hybrid too - great job Dusty thanks dusty, it looks like your risers are a bit lower too. i wanted to use clipons on top of the fork but as they are shorter it makes a harder. if the clipon are below you loose height. the biggest i can find is 3" which is the same height as orignal but one fitted below. unless i go for these www.ebay.co.uk/itm/Pro-Caken-Performance-Stunt-Adjustable-Shift-Clip-ons-Handlebars-For-50mm/232399130729?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20151005190540%26meid%3D04e2c0883c1e4557b34d86741e678461%26pid%3D100505%26rk%3D1%26rkt%3D1%26%26itm%3D232399130729&_trksid=p2045573.c100505.m3226
Post by marrcel on Oct 2, 2018 8:30:02 GMT 1
It looks german to me. A lot of clip on conversions there.
Post by aid22 on Oct 2, 2018 9:38:15 GMT 1
What about adjustable clip ons? I had some on my zxr750h2 and they were brilliant for me.
Just a thought.
Aid.
Post by midlifecrisisrd on Oct 2, 2018 18:04:43 GMT 1
Post by 17again on Oct 2, 2018 18:34:15 GMT 1
never even see these before.
Post by midlifecrisisrd on Oct 2, 2018 18:46:07 GMT 1
never even see these before. I had a chrome pair on my lc2 back in the 80's They can be either ace bars or normal but adjustable in all directions Very comfortable Steve
Post by dusty350 on Oct 2, 2018 19:02:32 GMT 1
Jotas bars were one of the many different combinations I had on my old 400 way back. As Steve says, multi adjustable Dusty
Post by 17again on Oct 2, 2018 20:08:12 GMT 1
Thanks I will look in to this
Post by fozzy17 on Oct 9, 2018 18:09:46 GMT 1
