Post by stusco on Sept 29, 2018 18:17:47 GMT 1
I agree you can definitely feel the difference all the small improvements add up ,hey nothings cheap on a rd
Post by stusco on Oct 5, 2018 16:22:24 GMT 1
This is the answer I got back from zeeltronic You had corrupted settings. Do you use non resistor spark plugs? Bad connection, bad earth, worn HT leads, or worn spark plug caps can also cause excessive EMI noise. I advised him I use b9eg plugs he said B9EG is non resistor spark plug, you must use BR9EG spark plugs. Do not need new CDI, we just programed calibration and everything is ok. All modern digital electronic equipment require resistor spark plugs...
Post by muttsnuts on Oct 5, 2018 16:33:17 GMT 1
funny that as he doesn't state that on any of his info and normally you run either resistive caps and non resistive plugs, or non resistive caps and resistive plugs, so does he reckon you need to run both then ? also, I've done loads of bikes with zeels fitted that are not running resistive plugs, in fact, the one on the dyno now is runnng a zeel and just B9ES plugs, and no issues
Post by wallcraft on Oct 5, 2018 22:28:50 GMT 1
The issue with resistor plugs or not, does his apply to 4lo motors or just the Ypvs?
Post by muttsnuts on Oct 6, 2018 15:17:49 GMT 1
The issue with resistor plugs or not, does his apply to 4lo motors or just the Ypvs? well if you take what Borut is saying on face value then you would have to say it applies to all bikes running zeels with the wrong plugs in as he is saying its wiping the maps out, if thst's the case then I am surprised there are any bikes running around with Zeel's on that are working correctly
Post by Tobyjugs on Oct 6, 2018 15:58:21 GMT 1
Don't forget Borut's native language is not English. The main thing is he has fixed the problem. It is always difficult to find the problem when you are not present yourself, so maybe he is just trying to give you possible causes and advising a solution which cannot cause any problems in the future.
Post by stusco on Oct 14, 2018 15:00:19 GMT 1
Just back from a test ride after refitting my repaired zeel ,the bike goes like a rocket again wheelies of the throttle in third with a little effort so I’m well happy ,pity it bloody freezing after only ten miles
