Post by wangwang on Sept 22, 2018 20:20:18 GMT 1
Has anyone fitted a set of RD250C spoked wheels in an LC? If so, is it a bearing and spacer change or a sleeve to make the spindles fit? Cheers wang
Post by mikee on Sept 22, 2018 21:22:40 GMT 1
The front spindle is a lot bigger on an ac 16mm vs 12 mm iirc but you can sleeve the bearings with top hat spacers Back wheel I have in mind is a bigger spindle , so you just file out the swinging arm slots
Did this swap on the swinging arm , lc arm in aircooled , but aircooled forks in an lc , so yup it’s do-able If I could get flicker to work properly I’d stick some pics up
Mike
Post by wangwang on Sept 22, 2018 21:46:28 GMT 1
Mike, PM sent
