N1 WOES
Sept 4, 2018 22:30:46 GMT 1
Post by liffy16 on Sept 4, 2018 22:30:46 GMT 1
Hello folks so my 350n1 is playing up starts fine from cold runs ok until i start raging her 1,2,3,4th gear pulls like an N1 should get to 5th just dies goes real flat?So ive checked float heights and adjusted to 21mm fuel tap seems okay on prim fuel flows freely,swapped coil with my other valve no difference?could it be the cdi unit breaking down?after bike dies if i slow down for a while then go for it again bike is okay ?any ideas fellow 2strokers
Post by mattybeckett on Sept 4, 2018 23:11:05 GMT 1
Is the breather clear on the tank ?
Post by rd350rob on Sept 5, 2018 7:55:31 GMT 1
My thoughts exactly. Sounds like it can't pull fuel quick enough, then recovers after a while of not-flat-out. Also check fuel cap- they can collect a lot of crud in them, and become (almost) airtight.
Post by muttsnuts on Sept 5, 2018 9:10:47 GMT 1
tank breather or fuel tap as mentioned above
N1 WOES
Sept 5, 2018 17:42:26 GMT 1
Post by liffy16 on Sept 5, 2018 17:42:26 GMT 1
Yea could well be that will investigate and report back
Post by rich on Sept 5, 2018 19:44:47 GMT 1
Best way to find out take it for thrash, when it starts losing power pull over and open the fuel cap. If you hear a sudden whoosh of vacuum, there's your problem.
Post by marrcel on Sept 5, 2018 20:09:54 GMT 1
And when there is no woosh. I suspect the fuel tap. The vac operated is a pita. Wil be replaced soon for a non vac operated over here. Waiting for the postman.
N1 WOES
Sept 7, 2018 13:18:28 GMT 1
Post by liffy16 on Sept 7, 2018 13:18:28 GMT 1
Okay stripped fuel cap and looks all clear even removed that little felt biscuit still the same pulls real strong to about 90 and bhuhh slow down wait and recover,fuel tap is not that old? Could not be anything electrical could it?
Post by marrcel on Sept 7, 2018 14:15:42 GMT 1
And on pri?
N1 WOES
Sept 7, 2018 14:48:09 GMT 1
Post by reggieperrin on Sept 7, 2018 14:48:09 GMT 1
Standard fuel tap is fine if overhauled and working how intended. My N1 has been flat out on the dyno and no issue with starvation at all.
N1 WOES
Sept 7, 2018 16:19:50 GMT 1
Post by liffy16 on Sept 7, 2018 16:19:50 GMT 1
Just to double check tried bike with fuel cap off my lc2 and the problem is still there ! checked fuel tap and thats clean as whistle ? this is whats making me think its not a fuel issue?
Post by marrcel on Sept 7, 2018 16:51:35 GMT 1
Not read in this topic you tried the pri stand on your tap🤔
N1 WOES
Sept 7, 2018 17:58:30 GMT 1
Post by liffy16 on Sept 7, 2018 17:58:30 GMT 1
Not read in this topic you tried the pri stand on your tap🤔 Yes marrcel and just swapped tanks with my lc2 still the same so its not the tap or cap?think i will swap carbs next?
Post by marrcel on Sept 8, 2018 13:04:26 GMT 1
Nothing wrong with checking and cleaning the carbies once in a while😉
N1 WOES
Sept 19, 2018 20:19:14 GMT 1
Post by liffy16 on Sept 19, 2018 20:19:14 GMT 1
just an update looks like it was float height after all too low on left carb
