Post by marrcel on Sept 3, 2018 13:10:02 GMT 1
Hello all Im in a dispute with yambits. I measured 26mm OD. Yambits says that al ypvs are 31,5? Yambits suggests someone has changed the case of my 31k. Who is right?
Cheers Marcel,
Post by LC_BOTT on Sept 3, 2018 15:14:49 GMT 1
Just buy a genuine water pump seal, Yambits rubber parts, not the best quality according to on here. Also, getting a refund is a struggle as well.
Post by huggy76 on Sept 3, 2018 17:08:28 GMT 1
I've just been and measured some old ones and they are 31mm OD x 13.5 wide.
On the ones I have here it has those measurements moulded in on the side also, so you might be able to see what the one you have has got on it.
Hope this helps.
Post by midlifecrisisrd on Sept 3, 2018 18:02:02 GMT 1
Hello all Im in a dispute with yambits. I measured 26mm OD. Yambits says that al ypvs are 31,5? Yambits suggests someone has changed the case of my 31k. Who is right? Cheers Marcel, Are you sure you never measured the oil pump seal hole Steve
Post by marrcel on Sept 3, 2018 19:24:35 GMT 1
[/quote]Are you sure you never measured the oil pump seal hole
Steve [/quote]
Yes i am very sure. 31mm dies not fit. I took out the old waterpump seal and this is 26mm. The oilpump seal is 25mm or so. Is it possible that someone placed an 31/26 adapter? This is difficult to see. But why? Any reason? In the meantime i placed 2 stacked 26/10/7 seals. Costs 1.7€ a piece.
Post by midlifecrisisrd on Sept 3, 2018 19:29:07 GMT 1
What size is the water pump bearing?
Post by midlifecrisisrd on Sept 4, 2018 9:18:27 GMT 1
Answering my own question here
Bearing is 35mm which is only slightly bigger than the seal so either your case has been messed with or it's not a 31k case
Post by marrcel on Sept 4, 2018 10:18:42 GMT 1
Mmm i closed the cover already. But i remember vaguely that 29L was stamped on the inside. So maybe a 4LO cover then?
Post by stusco on Sept 4, 2018 11:44:58 GMT 1
Just checked my spare casing you are trying to fit the seal in the wrong place the seal goes in from the inside (oil side) then the bearing,the 26 mm is inside the water pump behind the impeller
Post by midlifecrisisrd on Sept 4, 2018 11:58:21 GMT 1
Mmm i closed the cover already. But i remember vaguely that 29L was stamped on the inside. So maybe a 4LO cover then? 29l is ypvs Steve
Post by marrcel on Sept 4, 2018 12:18:05 GMT 1
Just checked my spare casing you are trying to fit the seal in the wrong place the seal goes in from the inside (oil side) then the bearing,the 26 mm is inside the water pump behind the impeller Well i did put it in from the oilside. In my cover the 26mm is inside the oilside. It is not on the impellar side. The axle hole is about 11mm. The axle hole is water wetted. The 26mm hole is 14mm thick and oil wetted. I forgot to take pictures🤭
Post by 4l04ever on Sept 4, 2018 12:24:26 GMT 1
Sounds like it needs to come back off and get some pictures taken......
Post by marrcel on Sept 4, 2018 14:28:59 GMT 1
Sounds like it needs to come back off and get some pictures taken...... Yes but only when i have pea soup instead of oil😉 Did stusco had spare open? Any pics would be appreciated🤗
Post by stusco on Sept 4, 2018 14:30:02 GMT 1
Post by 4l04ever on Sept 4, 2018 14:53:21 GMT 1
From the back, you have to put the seal in first, then the bearing.... :-)
Post by marrcel on Sept 4, 2018 19:37:01 GMT 1
In my pump housing is the hole for the impeller axle say 11mm🤔
Post by stusco on Sept 4, 2018 19:39:10 GMT 1
In my pump housing is the hole for the impeller axle say 11mm🤔 Is the old seal still fitted?
Post by marrcel on Sept 5, 2018 8:11:32 GMT 1
No i replaced it with 2 stacked 26/10/7 seals. So i had the axle hole free. And the size of the hole was slightly, say 11mm, 1mm bigger than the 10mm pumpaxle.
Post by Tobyjugs on Sept 5, 2018 11:55:46 GMT 1
Marrcel just go back to a standard seal. This weekend i will be in Lelystad. I think close to where you live? if so i will dig out a seal for you if you need it quickly.
Post by marrcel on Sept 5, 2018 14:40:51 GMT 1
Marrcel just go back to a standard seal. This weekend i will be in Lelystad. I think close to where you live? if so i will dig out a seal for you if you need it quickly. Thank you very much Tony. But 31,5 mm seal wont fit. Im happy now with my 26mm seals. Just very curious what kind of cover do i have on my 31k? Wassup @ lelystad?
Post by stusco on Sept 5, 2018 14:48:03 GMT 1
Can you take a picture of your casing,as this is very curious
Post by chippy348 on Sept 5, 2018 15:44:06 GMT 1
Attached photo, some seals are 2 parts pressed together rather than just one whole part. What the op looks to have done is flicked the inner part of the seal out and left the outer in the case. Then got some seals and stacked them inside the old outer body.
Post by stusco on Sept 5, 2018 16:00:17 GMT 1
That sounds plausible to me ,I would fit the correct seal properly maybe an hours work
Post by Tobyjugs on Sept 5, 2018 16:12:54 GMT 1
Marrcel just go back to a standard seal. This weekend i will be in Lelystad. I think close to where you live? if so i will dig out a seal for you if you need it quickly. Thank you very much Tony. But 31,5 mm seal wont fit. Im happy now with my 26mm seals. Just very curious what kind of cover do i have on my 31k? Wassup @ lelystad? Flatlands Festival
Post by marrcel on Sept 5, 2018 16:26:52 GMT 1
Attached photo, some seals are 2 parts pressed together rather than just one whole part. What the op looks to have done is flicked the inner part of the seal out and left the outer in the case. Then got some seals and stacked them inside the old outer body. This might be the explanation. But i want also a picture like you do. I agree open it up again will take an our for a specialist. But in my shed undo the fluids again is to much of a hassle. But the first thing i do when it is apart again is take a picture. Last time the seal was changed in 1996. May be another opportunity in 2040!😜
