Post by wangwang on Aug 13, 2018 21:00:19 GMT 1
Anyone recommend any decent pattern seals for YPVS waisted forks?
Cheers
wang
Post by stusco on Aug 13, 2018 21:24:16 GMT 1
Got mine from norbo
Post by kostas on Aug 14, 2018 6:02:31 GMT 1
Got really bad experience with pattern seals for my forks. The brand was “extreme seals”.. the left was leaking within a year and both were kind of stiff and did not allow for proper fork operation.
Anyway, replaced those with OEM which are 11 Euro each from the local Yama dealer. OEM are “Nok” brand.
Kostas
Post by stusco on Aug 14, 2018 7:37:21 GMT 1
I thhink norbos are extreme seal I fitted these after my genuine ones leaked after a couple of hundred miles
Post by kostas on Aug 14, 2018 9:32:21 GMT 1
OEM is a two way seal with spring fitted both sides. Extreme Seals is a two way seal with spring fitted on one side only.
Kostas
Post by wangwang on Aug 14, 2018 21:27:21 GMT 1
Cheers. It says in Haynes that LC2 uses 253cc of 10w30 SE motor oil in the forks, is this correct?
Post by stusco on Aug 15, 2018 7:34:33 GMT 1
That’s what I put in mine,had to google cc it turns out it’s the same as ml
Post by Tobyjugs on Aug 15, 2018 8:53:29 GMT 1
I've used fork seals from Tourmax for all sorts of bikes with no problems.
Post by Nicky on Oct 7, 2018 12:58:13 GMT 1
I'm replacing mine now (4L0) 1981. After I've removed the clip above the seal, I can't see where the seal ends and the fork leg starts. I started by prying out the rubber parts to the seal but am left with what looks like a metallio ring rusted against the fork leg. I'm nervous about trying to pry that using the fork leg top as the fulcrum - any tips please? Haynes says to pry out the seals using a screwdriver and YouTube has a lot of vids with guys pulling the stanchion out against hammer-style to remove the seal.
Post by earthman on Oct 7, 2018 15:58:57 GMT 1
I've used fork seals from Tourmax for all sorts of bikes with no problems. Like with the petrol tank fuel tap, I wonder if the OEM fork seals are actually Tourmax ones??
Post by wangwang on Oct 7, 2018 22:11:18 GMT 1
I'm replacing mine now (4L0) 1981. After I've removed the clip above the seal, I can't see where the seal ends and the fork leg starts. I started by prying out the rubber parts to the seal but am left with what looks like a metallio ring rusted against the fork leg. I'm nervous about trying to pry that using the fork leg top as the fulcrum - any tips please? Haynes says to pry out the seals using a screwdriver and YouTube has a lot of vids with guys pulling the stanchion out against hammer-style to remove the seal. I use the slide hammer method, doesn't always take out the seal, but once the stanchion is removed and out of the way it's easier to get the seal out.
