Post by 17again on Jul 29, 2018 10:47:33 GMT 1
Can someone tell me if I were to buy a Lc with standard wheels using a metmachex swingarm
is is it possible to fit a rgv 250 rear wheel in it or is a special made arm for that wheel to fit.
Thanks
Post by dusty350 on Jul 29, 2018 10:59:43 GMT 1
No, it wont fit unfortunately. The Met arm for an Rgv wheel is a bigger extrusion; 20150616_102547 by David Miller, on Flickr Plus it has a machined pin to take the Rgv caliper carrier. It's also wider at the wheel spindle for the wider wheel, different wheel spindle size too. Dusty
Post by 17again on Jul 29, 2018 11:12:04 GMT 1
Thanks dusty it’s good info to know.
Post by plumma on Jul 31, 2018 2:04:06 GMT 1
Off topic, but how good do plain white wheels look!
Post by 4l04ever on Jul 31, 2018 11:36:34 GMT 1
You could fit a TZR1254FL rear wheel 17 x 3.5 in, as I have one in my standard 4L0 swingarm. Needs spacers and the carrier modifying....and a caliper hanger...
Post by reedpete on Jul 31, 2018 17:36:46 GMT 1
4FL or 4DL, ?
Post by abar121 on Aug 1, 2018 13:00:11 GMT 1
Off topic, but how good do plain white wheels look! They do until you lube the chain.
Post by 4l04ever on Aug 2, 2018 10:08:05 GMT 1
Both are 17 x 3.5. The 4DL wheel is Brembo wheel and does not look as nice as the 4FL/4HW model wheel. I thing the 4DL wheel may be heavier too, as it looks chunkier.
