Post by donkeychomp on Jul 20, 2018 23:19:04 GMT 1
Some of you have seen the RD50/60/LC/AC thing I'm building. The plan is to not bother painting powder coating or polishing anything just yet all I want to do is go get an MOT. So the easiest route is a day time MOT. For that I need a speedo and a horn. No electrics needed there. However I do need a coil. What can I use? Any ideas? And a carb. 22mm sounds about right to me but I could be wrong. Also an exhaust but I'll buy something and (ahem) adapt it to fit.
Wondering if I've missed anything. I have an engine, wheels with brakes. New bearings on everything. A number plate! Do I need a rear light too? Saw an Aprilia rs140 (big bore kit) the other day and that had a rear light...
Any help is welcomed!
Post by JonW on Jul 21, 2018 1:47:48 GMT 1
you'll need a brake light I'd think.
Post by veg on Jul 21, 2018 7:30:14 GMT 1
Need a brake light deffo my drz 400 was daylight use only that is one thing they check
Post by dusty350 on Jul 21, 2018 7:36:43 GMT 1
Would one of Norbos banshee coils work i wonder ?
Dusty
Post by oldelsieboy on Jul 21, 2018 9:54:04 GMT 1
Post by veg on Jul 21, 2018 11:26:42 GMT 1
My Drz was failed because it didn't have a stop lamp so that is interesting. Tbh though why would you not want one? If you don't fit one as well and you are in an accident would there be any liability your way?
Post by jon on Jul 21, 2018 12:02:01 GMT 1
Post by donkeychomp on Jul 21, 2018 20:56:46 GMT 1
You don't need a brake light but it's insanity not to have one so I will. Dusty I didn't realise those coils were in 2 parts does he sell them separately?
Any carb ideas lads? Exhausts? The little RD has the screw on type of exhaust flange, not sure if this restricts my options or not. Are they easy to attach to a pipe?
Post by dusty350 on Jul 21, 2018 21:23:06 GMT 1
Hi mate I think Norbo sells the Banshee coils for 125 lc's which only require 1. Worth asking him Dusty
Post by donkeychomp on Jul 21, 2018 21:38:55 GMT 1
Aha! I shall matey!
Post by donkeychomp on Jul 21, 2018 23:41:39 GMT 1
Had a look and couldn't see a Banshee coil but he has ad RD80LC one...that should do it!
Post by midlifecrisisrd on Jul 22, 2018 12:52:59 GMT 1
Will a dt80 carb do
They mount on a spigot
Post by donkeychomp on Jul 22, 2018 21:02:28 GMT 1
Not sure but I think most Yam carbs from that era could be adapted to fit. Just ordered a Banshee coil ta for the tip Dusty!
