Post by headcoats on Jul 19, 2018 9:59:46 GMT 1
Will have to do this soon but noticed that a lot of bikes have the hose "flapping" where it loops over the chain adjuster to the caliper
The above pic has a clamp to steady the hose , so is that standard on RGV's or has it been added ?
Post by jessy03 on Jul 19, 2018 10:17:26 GMT 1
If it’s this one then it’s std rgv
Post by headcoats on Jul 19, 2018 10:20:24 GMT 1
Yes that looks like the one I'm missing
Is it a wire bracket with a grommet and is there a hole there for it to fit ? Edit
Just found the hole !
Post by jessy03 on Jul 19, 2018 10:21:39 GMT 1
Yes it is, I have one on the bench,I’ll post a pic
Post by jessy03 on Jul 19, 2018 10:26:00 GMT 1
This is the one, think they nla from Suzuki
Post by jessy03 on Jul 19, 2018 10:29:52 GMT 1
Post by headcoats on Jul 19, 2018 10:40:59 GMT 1
Cheers Jessy !
Post by headcoats on Jul 19, 2018 11:01:37 GMT 1
Post by jessy03 on Jul 19, 2018 12:13:30 GMT 1
You could make one, coat hanger and fit a sleeve over it (black oil pipe)
Post by jessy03 on Jul 19, 2018 12:15:34 GMT 1
Post by LC_BOTT on Jul 20, 2018 19:40:30 GMT 1
Was going to say, stainless welding rod, and make your own
Post by bazzer5115 on Jul 20, 2018 20:48:56 GMT 1
I have always made my own,from welding rod,brazed ends up and had powered coated.
Post by loudpipes on Jul 20, 2018 21:37:10 GMT 1
You dont need this if you make pipe shorter. i used hel brake hoses set pipe at correct angle then warm up heat shrink to lock pipe angle in place.
