Post by shaunyb63 on Jul 11, 2018 16:45:18 GMT 1
Hi, just installing my water pump seal on 250lc and just wondered.. does the seal have to fit tight to the inner edge of the case or not?.. just asking because if I do fit it tight then it will overlap the water channel slightly which may restrict the flow of coolant, or is it installed with the seal level with the water Chanel? It is a genuine Yamaha seal from Fowler’s. Also the genuine Yamaha bearing fits real easy into the housing.. almost too easy.. is this normal or would it be better to put some bearing lock in? by the way the old bearing came out without too much bother , it wasn’t a tight fit at all. Any advice from the experts would be greatfully received.
