Post by jon on Jul 7, 2018 8:31:52 GMT 1
Hi all,
Has anyone fitted a new chain to their F2 (I expect others are the same) recently and noticed the position of the axle in the adjuster slots?
I talking about a standard 106 link with 17/39 sprockets.
Is it all the way to the front?
Post by mellow on Jul 7, 2018 9:35:39 GMT 1
I have. I can't remember. I could pop down shed later and look
Post by JonW on Jul 7, 2018 11:41:11 GMT 1
should be towards the front so you can adjust it backwards as it wears and stretches.
Post by jon on Jul 8, 2018 7:54:03 GMT 1
should be towards the front so you can adjust it backwards as it wears and stretches. If possible I’d like an accurate measurement. I’m thinking of using a 107 link chain to avoid some clearance issues on a different wheel, but worry that if I do I’ll have very little adjustment unless I elongate the slot, which I would prefer not to have to do. Jon
Post by JonW on Jul 8, 2018 13:39:19 GMT 1
I always buy a longer chain than I need and then cut off the links I dont need, mostly Ive found the longer lengths can cost the same or even less depending on the brand and/or who sells it.
