Convert..
Jun 25, 2018 15:37:44 GMT 1
via mobile
Post by doohanno1 on Jun 25, 2018 15:37:44 GMT 1
What list of parts do i need to convert a f2 into a n2.?? I'll put an add in the wanted section shortly if anybody has any bits. Tks... ( not worried about having the exact petrol tank.)
Post by Yogi on Jun 25, 2018 16:03:45 GMT 1
Main parts are
Lc2 top yoke N1/n2 clocks,headlight bracket
Handlebars,headlight of your choice
Ideally Lc2 clutch cable an throttle cable,,,although you can just get away with the standard ones
Matt
Convert..
Jun 25, 2018 16:31:39 GMT 1
via mobile
Post by midlifecrisisrd on Jun 25, 2018 16:31:39 GMT 1
Main parts are Lc2 top yoke N1/n2 clocks,headlight bracket Handlebars,headlight Ideally Lc2 clutch cable an throttle cable,,,although you can just get away with the standard ones Matt You been out in the sun too much? N2 has the same clip ones and top yoke as f2 ๐ Steve
Convert..
Jun 25, 2018 16:33:34 GMT 1
via mobile
Post by midlifecrisisrd on Jun 25, 2018 16:33:34 GMT 1
I have spare clocks ๐
Post by Yogi on Jun 25, 2018 17:21:28 GMT 1
Main parts are Lc2 top yoke N1/n2 clocks,headlight bracket Handlebars,headlight of your choice Ideally Lc2 clutch cable an throttle cable,,,although you can just get away with the standard ones Matt You been out in the sun too much? N2 has the same clip ones and top yoke as f2 ๐ Steve Didn't mean from an n model,that's why I wrote it on another line,,,trust you to twist my words I meant he also needs Matt
Post by jon on Jun 25, 2018 18:08:35 GMT 1
I have spare clocks ๐ Steve Arenโt TZR clocks the same? Jon
Convert..
Jun 25, 2018 18:18:26 GMT 1
via mobile
Post by midlifecrisisrd on Jun 25, 2018 18:18:26 GMT 1
I have spare clocks ๐ Steve Arenโt TZR clocks the same? Jon Ish Don't tzr ones have the cover over the idiot Also to be picky a 150mph Speedo You need the f2 clock loom as it is different to the n1/2, txt and fzr clock looms Steve
Post by rich on Jun 25, 2018 18:23:49 GMT 1
Horn bracket, N2 Horn is under the tank. Rad grill
Post by jon on Jun 25, 2018 18:37:57 GMT 1
Arenโt TZR clocks the same? Jon Ish Don't tzr ones have the cover over the idiot Also to be picky a 150mph Speedo You need the f2 clock loom as it is different to the n1/2, txt and fzr clock looms Steve Canโt be sure, but I think the cover over the idiot lights is a Japanese market thing? Not sure about the speedo? The Brazilian 350 also had a 150mph clock like the 509 so maybe? Jon
Convert..
Jun 25, 2018 22:00:38 GMT 1
via mobile
Post by doohanno1 on Jun 25, 2018 22:00:38 GMT 1
Hmm, might consider top yoke conversion.. Are the clocks not close enough in looks that i may just need the bracket.? Never thought about rad and guard.๐
Post by Shytalk on Jun 26, 2018 10:57:42 GMT 1
Hmm, might consider top yoke conversion.. Are the clocks not close enough in looks that i may just need the bracket.? Never thought about rad and guard.๐ Radiator is still the same, just the guard differs, clocks are mounted differently using the proper N1 / 2 bracket so the standard F2 ones wonโt fit without some fabrication of brackets, starts adding up nowadays. If you go for risers you still need a round headlight and fixings.
